Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
LOOKING TO COMVERT
Old Apr 28, 2007 | 04:00 AM
gotay5's Avatar
LOOKING TO CONVERT
I'm looking to comvert my arc welder to tig welder any ideas.
thanx: carlos
Old Apr 29, 2007 | 02:26 AM
TheLegedaryErin's Avatar
Re: LOOKING TO COMVERT
You say you have a Arc machine, By that I am assuming you have a Stick machine or possibly a wire feed or MIG Box. TIG is Something completely different requiring Special equipment and a Different then mig or stick. If you have a Wire feed you might be able to Convert it to a mig by buying a Kit from the original manufacturer. here is better info Tig
http://en.wikipedia.org/wiki/Gas_tungsten_arc_welding
Old Apr 29, 2007 | 12:54 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
or actually, an arc welder is a stick welder. It can be converted to tig. Typically you'll need a fairly big/heavy duty machine to set up as a tig (and be able to do much with it). One question would be, what do you plan to use it for? if you do a search, I believe there have been a few posts about this in the past.
rnx
Sep 19, 2012 05:36 AM
Vetruck
Southern California Area
31
Jun 23, 2008 02:05 PM
TheViper
Jul 30, 2003 04:41 PM
NOSFEDGTA
Apr 1, 2003 10:01 PM
