Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
gauging intrest in twin turbo headers for ls1-lsx and sbc gen1
Old May 30, 2007 | 01:09 PM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
ok im looking to see if there is any intrest in twin turbo headers. they will be made out of mild steel you have your choice on 1-5/8 or 1-3/4 primary tubes 16 gauge or 18 gauge. The tubing will be mandral bent running in to a 4 to 1 collector (3in) with your choice of turbo flange. The headers will look like the ss auto chrome headers but the quality will surpass any thing that has come out of there door.
right now im working on the ls1-lsx motor for tight location set ups. I have about 600 bux in to the headers alone. the price will drop as soon as I start to get the flanges for the turbos and manifolds laser cut.
depending on the buyers choices the prices are going to start around 500.00 dollars and top out around 550.00 or 575.00
let me know what you guys think?
Old May 30, 2007 | 03:43 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: gauging intrest in twin turbo headers for ls1-lsx and sbc gen1
I think you need to use thicker wall mild steel (.125" min.) or supply the end user with support brackets. Thicker wall is more preferable (heat & strength). You will find it is much harder to build with the stronger material. Especially if you use pipe with 1.6" ID (same as 1-3/4" 16 gauge pipe). That drives the cost up and that is why people don't sell turbo headers. I hope it works out for you.
Old May 31, 2007 | 06:54 AM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
ill have to price the tubeing. I cant see it costing to much more if you can find some one to bend it, if not it wouldent be to hard for me to pick up an bender and make a few J bends.
Old Jul 16, 2007 | 12:15 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Go for Stainless. If you want to sell something its my opinion to make a truly GREAT product and charge accordingly. EG. Hawks LS1 headers sell fast but they are very nice pieces and they aint none too cheap.
Good luck bro!!
Street Lethal
Apr 30, 2019 12:14 PM
bjpotter
Jan 22, 2019 12:27 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
