Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Alternator mount modification
Old Jul 3, 2007 | 08:21 AM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
I have had a few requests on how I was able to get the proform tall valve covers fit with the standard late model alternator mount. The stud on the back of the alternator is to long and interferes with the valve cover. Throw away the black plastic cap, and replace with old 90 degree angle spark plug boot trim as necessary. Place the nut and wire on the stud of the alt cut off excess stud it is still a tight fit but it does fit. My car is full of these kinds of modifications nothing bolt on is truly bolt on
CG
Old Jul 3, 2007 | 01:14 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Re: Alternator mount modification
nice job. those wussy plastic caps always scared me anyway... the boot looks like a good plan even if you are rocking STOCK valve covers.
Old Jul 3, 2007 | 02:15 PM
Demon355's Avatar
Thanks for the help dude, appreciate it. I'll be doing this ASAP as soon as I find an old wire boot
Old Jul 3, 2007 | 03:11 PM
AC's Avatar
AC
Car: Used to drive a camaro
Nice work. You can also do what I and a few others did....unscrew the 3 or 4 bolts on the back and "clock" or rotate the back half 180degrees.
Old Jul 3, 2007 | 03:24 PM
Demon355's Avatar
Any pictures of this?
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
