Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4th gen batt. tray/coolant can
Old Jul 24, 2007 | 03:26 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
yes i did a search , could not find what i wanted . i know many have installed the 4th gen coolant tank/battery tray . how ? problems ? fabrication req. ? anyone have pics ? also same on washer tank . thanking in advance .
UNCLE TOM
Old Jul 24, 2007 | 05:11 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: 4th gen batt. tray/coolant can
https://www.thirdgen.org/forums/body...t-fit-rad.html
https://www.thirdgen.org/forums/body...ant-wiper.html
Found this thread by a search
Basickly you need to cut the battery tray out and replace with the 4th gen unit, may have some issues with the neck, but pretty easy to do.
The washer tank is really easy, just extend the wires and the washer fluid tubes. You do need to remove a small support, but it's only held in by 3 bolts.
Old Jul 24, 2007 | 10:23 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Do tell. I tried like hell to get it in there, and it will NOT fit. Do you have TPI? Maybe thats my problem, and it just wont work with the factory TPI ducting.
Old Jul 31, 2007 | 07:01 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
A guy on here was able to hide all of the washer bottle except for the cap. He showed me pictures, and I tried and tried... I couldnt do it. I built a new triangular brace for the hood support and all. Mine is all cut up...it wont look TOO bad when Im done. Better than the yellowed dirty bottle that was in there. And since I cant get my original washer bottle anymore, I went with the 4th gen. Oh...and the 4th gen pump really puts out the pressure! I found leaks right away and had to redo my hoses. Thank thing turned my washers from squirt guns to super soakers!
As for the coolant bottle... What I did since I had a donor car, is I cut the area for the bottle out of the donor, and then layed it in my car on the passener side where my charcoal canister was. Traced the opening (weird shape), cut it, cut some of the fender brace that was below it, and that was that. Fits perfectly, looks great, and all you can see is the reservoir cap.
J.
Old Aug 1, 2007 | 10:20 PM
CanadianRoots's Avatar
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
Any Pictures??
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
cam-mike
Aug 24, 2015 07:23 AM
