4th gen Coolant and Wiper Tank + Summit Alum. Radiator PICS
Old Jan 21, 2007 | 11:59 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Here ya go... Sorry I can't seem to hold a camera still....
Attached Thumbnails 4th gen Coolant and Wiper Tank + Summit Alum. Radiator PICS-1.jpg   4th gen Coolant and Wiper Tank + Summit Alum. Radiator PICS-2.jpg   4th gen Coolant and Wiper Tank + Summit Alum. Radiator PICS-3.jpg
Old Jan 21, 2007 | 12:07 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
lookin good man
Old Jan 21, 2007 | 12:55 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Pretty cool man. Looks like I'm gonna be hitting up the junk yard tomorrow.
Old Jan 21, 2007 | 01:10 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
do you need the summit radiator to pull this off ?
Old Jan 21, 2007 | 01:31 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
How much of the radiator is that tank blocking?
Any heat issues?
Old Jan 21, 2007 | 02:06 PM
crrllmich's Avatar
Engine: L03, LS1
O the 4th gen tanks had nothing to do with the radiator being installed. I just happened to do them when I put the rad. in.
Old Jan 21, 2007 | 03:04 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
The 4th gen washer tanks go in front of the plastic shroud that directs air to the radiator, so it doesn't block the airflow at all.
Old Jan 21, 2007 | 07:45 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Pic doesn't work.
Old Jan 21, 2007 | 07:48 PM
crrllmich's Avatar
Engine: L03, LS1
Had a few people say that so...Ill fix it.
Old Jan 21, 2007 | 07:50 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I like it Mike, looks good...giving me ideas.
Old Jan 21, 2007 | 08:12 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Very nice I hope to do this myself!
Old Jan 21, 2007 | 08:58 PM
cdoyle's Avatar
Looks nice, really opens the engine bay up.
Might have to consider doing this
Old Feb 20, 2007 | 12:00 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Just found this and am working on the same swap. Do you have any better pics of the hood latch support? Having difficulty getting that to fit in there just right with the washer fluid bottle. Did you have to notch it out, or just bend it a little out of the way?
Old Feb 20, 2007 | 04:32 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
I'm guessing it wont work with a stock TPI airbox?
Old Feb 20, 2007 | 04:48 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
yeah, how easy is it to do?
so if i ever see one at a junkyard, ill be sure to grab it
Old Feb 20, 2007 | 06:06 PM
krisb410's Avatar
The washer tank is so easy to do. I bought one and did it in like 30 min. without any help other than I heard some people have done it. Nothing hard to fig out.
Old Feb 20, 2007 | 08:00 PM
crrllmich's Avatar
Engine: L03, LS1
I beleive some years differ but I can say my 91 did not require modifications to the hatch support. BUT I did have to remove the front bumper support arm. I didn't notice any difference in the strength of the bumper. I sat on it afterward myself (230 pounds) with no problems.
As for the battery tray/overflow thats a little more takes a little more layout planing. I will take closer pics if I can remember.
Old Jun 15, 2007 | 12:40 AM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: 4th gen Coolant and Wiper Tank + Summit Alum. Radiator PICS
Better pics .... . wiating.... PLEASE
Old Jun 15, 2007 | 01:27 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Makes the engine bay super clean looking!
Old Jun 15, 2007 | 02:43 AM
MajorPayne's Avatar
Car: 1987 Red Camaro Iroc
Engine: Stock lb9 305 TPI
Transmission: Th700R4
Axle/Gears: 3.23 posi, disc brakes.
crrllmich, what is the part# on that radiator? Was it a drop in, or did it require modifications?
Old Jun 15, 2007 | 06:18 AM
crrllmich's Avatar
Engine: L03, LS1
I had to modify the fan shroud... or what ever its called for an electrical fan.
As for fitment and hookups the top hose is REALLY tight going on. I actualy plan going to a billit hose or something because it worries me.
Also I removed my A/C at the same time so not sure if there was fit issues with the A/C radiator.
I will get more pics up probaly after this weekend as I am installed a non-AC heater box as well.
SUM-380455
Part number.
Old Jun 15, 2007 | 09:57 AM
Stephen's Avatar
Car: 87 GTA
I wanna do that, but with Pontiacs, it isn't as open. We have a piece of sheetmetal covering that area. It might able to be unbolted, and that 4th gen piece dropped in, but I suspect I'd hafta cut an opening for the filler neck.
Old Jun 15, 2007 | 10:08 AM
crrllmich's Avatar
Engine: L03, LS1
Theres a picture of someone doing it with a pontiac on here somewhere. With enough searching you may be able to turn it up.
Old Jun 15, 2007 | 10:23 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
ditto, I'd like to know the pn as well.
Old Jun 15, 2007 | 10:26 AM
crrllmich's Avatar
Engine: L03, LS1
I posted it above but here it is again:
SUM-380455
Old Jun 15, 2007 | 10:32 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Sum-380455
Old Jun 17, 2007 | 11:33 AM
crrllmich's Avatar
Engine: L03, LS1
Ha I thought posting it twice was enough but threes a charm I guess.
Old Jun 29, 2007 | 05:30 PM
crrllmich's Avatar
Engine: L03, LS1
New pics here:
https://www.thirdgen.org/forums/body...t-fit-rad.html
Old Jun 30, 2007 | 02:37 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Here:
400% better then stock, but harder to do the washer tank on the birds.
Kevin D.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
fonzie85
Aug 13, 2015 11:50 AM
