Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
89 R.S. TRANS ISSUE
Old Aug 3, 2007 | 11:15 AM
t-FLY's Avatar
89 R.S. TRANS ISSUE
HOW DO I CHANGE THE REAR SUSPENSION ON MY 89 RS SO I CAN PUT MY TH350 TRANS IN THE TORQE ROD WONT FIT THE TRANS?
Old Aug 3, 2007 | 07:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 89 R.S. TRANS ISSUE
FIRST YOU TURN OFF THE CAPS LOCK!!!
hurst and b+m, sell conversion kits that will allow you to relocate the torque arm from the trans, or you can buy a tunnel mount torque arm setup from Spohn performance. you need a different length driveshaft.
there is really no way to change the design of the rear suspension unless you install ladder bars or tub the rear and install a 4 link setup.
theshackle
Sep 17, 2020 08:26 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
