Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Convert vaccum ball to a Brake vaccum can???
Old Aug 31, 2007 | 11:51 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Do you guys think it is possible to convert the black vaccum ball to a vaccum can for the brake booster?
Would it work if I drilled two holes, one with a brake booster valve and the other with a regular fitting. Then hook it up like a vaccum canister?
I know I can pick one up from jegs for $31, but the vaccum ball already has a good hidden mount.
What do you guys think?
Old Aug 31, 2007 | 12:30 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Convert vaccum ball to a Brake vaccum can???
please refer to it as "the orb of power!!!!!"
but yea, as long as you dont crack it when putting the fittings in, it'll work... just be careful.. it cracks very easily.
Old Aug 31, 2007 | 12:37 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I did kinda notice it glowing the other night.
I think I will try it.
Thanks.
Old Aug 31, 2007 | 03:40 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I was wondering about that myself, I think I'll give it a shot too.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
dyeager535
Aug 28, 2015 08:10 AM
zayne0
Aug 24, 2015 07:22 PM
