Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4x4 bird
Old Oct 18, 2007 | 05:46 AM
thebird91's Avatar
Car: 91 firebird
Engine: V6
Axle/Gears: stock
4x4 bird
iv seen it done a couple times i was just wondering how to lift my 91 firebird
Old Oct 18, 2007 | 08:23 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 4x4 bird
Find a 4x4 with the same wheel base. Install third gen body on 4x4 frame.
Old Oct 22, 2007 | 08:59 PM
fbodyguy86's Avatar
Car: 92 camaro rs
Re: 4x4 bird
i believe the 82-94 ws10 blazers have the same 108 in wheelbase but not 100% sure try that out
Old Oct 22, 2007 | 10:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 4x4 bird
Third gens are 101"
Even the old K5 Blazers were 104". I'm sure if the third gen body sat high enough to clear the tires, the extra 3" of wheelbase wouldn't be noticed.
Old Oct 22, 2007 | 11:12 PM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Re: 4x4 bird
Here is a picture from PhillyTurboSix.
Old Oct 22, 2007 | 11:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 4x4 bird
Put on your flame suit bud, you're in for a cookin'...
Old Oct 22, 2007 | 11:24 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: 4x4 bird
and while your at it take a corvette and lift it. make sure the get the official red neck tire of f body 4x4's the super swamper. and just go on ahead and put mud flaps on, sidepipes, a hitch and cow catcher on the front. I mean hey... you might as well go all the way and get that $1,000 bucks from country fried home videos.
HERE'S YOUR SIGN
Old Oct 23, 2007 | 12:56 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Re: 4x4 bird
At least he is doing it to a bird and not a Camaro...
Old Oct 23, 2007 | 06:21 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Re: 4x4 bird
In 1986 in the backwoods of arkansas. I saw 3 like that. A 72 Camaro, a chevette and a vega. The Vega looked good, the chevette was still a chevette and the Camaro......no comment.
Old Oct 23, 2007 | 06:25 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Re: 4x4 bird
When I was up in silver lake Michigan (Closest sand dunes to Ontario) I seen a 1989 Firebird TA covered in sand, normal street tires, license plates, the whole nine yards, but it could've had a 4X4 frame.. I never understood the purpose of it, but it's your car/money..
Old Oct 23, 2007 | 08:51 AM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: 4x4 bird
Old Oct 23, 2007 | 04:50 PM
ryan91rs's Avatar
Transmission: 4L60
Re: 4x4 bird
yes at least it's a firebird!
4playta that is a heck of a gear ratio in that car. a full 373:1, you could pull a house with that! lol!
Old Oct 23, 2007 | 06:08 PM
racerx520's Avatar
Re: 4x4 bird
ya know ive seen a couple cars like this (notin person) but i think they look kinda cool....call me a goober or whatever you would like but i think that its pretty neat...if you like 4 wheeling and f-bodies that much, then hell....i dont see why not combine the two lol....ive seen this one old el camino (i'm gonna guess about 68) on a jacked up blazer frame and it looks pretty cool lol
Old Oct 23, 2007 | 07:39 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: 4x4 bird
If they are lifted to fit 26inch bling bling, then no.
If they are lifted to go where other f-bodies cannot, then yes!
Old Oct 23, 2007 | 09:10 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
Re: 4x4 bird
I wouldn't do it I would just get a 4x4 truck or something but its your car you can do what you want to it.
Old Oct 26, 2007 | 03:39 PM
ruberbanman126's Avatar
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
Re: 4x4 bird
i wouldnt waste a good f-body, if u really are serious about a 4x4 f-body then i would get a fiberglass body from this site http://www.vfnfiberglass.com/site.htm
Old Oct 26, 2007 | 06:59 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
Re: 4x4 bird
High lift coil springs (JcWhitney sells 'em) and fender trimming should get you at least 31-33" tires under it. Please use a rust free mint body for this so as to **** off as many purists as possible, in twenty years you'll even hate yourself for doing it when the value of your 1500.00 fbods worth 5x that.
They doo look pretty cool don't they?!?
1970's-80's fullsize blazer is 112" wheelbase k5/k9 style, not sure of the '60's blazers or the newer s10 based stuff.
To each there own. I'd wanna see Boggers though, tunnel ram straight out the hood, zoomies coming out of the front fenders like an old fighter plane, prerunner bumper w/ lights oh and an aluminum skid plate.
With crossover steering you could use the fbody's steering box, you'd have to do some major unibody reinforcement. I think stacked frames look bad of course its gonna look like a freak anyway so whatever.. you could probably use the stock spring pockets leaf springs stink, coils are better in that you can get more travel, better rates, etc.. Maybe the rear leafs out of a new toyota? pickup would work up front long/thin enough to give a good ride/flex. Fullsize truck leafs don't work good on car/s10 conversions they are oversprung (no suspension movement) ride like junk and bust axle parts if you ever jump it- and why wouldn't you jump something like a 4x4 fbody, otherwise you'd be called a rhedneck and a poser.
Old Oct 26, 2007 | 08:26 PM
FabricatorX's Avatar
Re: 4x4 bird
Oh man... oh man... lol
Old Oct 27, 2007 | 07:01 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
Re: 4x4 bird
if you go 4X4 make sure you do it right...use a solid axle in the front
Old Oct 27, 2007 | 07:08 PM
ryan91rs's Avatar
Transmission: 4L60
Re: 4x4 bird
I thin i just shed a tear for the first time in ten years. Poor f body won't see it coming.
Old Oct 27, 2007 | 10:46 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
Re: 4x4 bird
WTF
Old Oct 27, 2007 | 11:19 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: 4x4 bird
even as a 4x4 the firebird looks better then one a them kitt cars ......
Old Oct 28, 2007 | 04:19 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: 4x4 bird
This one is dedicated to the Camaro guys...afterall, I wouldn't want you guys to feel left out...
Saw this beauty in one of the back roads near an old garage here in the south...
Old Oct 28, 2007 | 06:11 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: 4x4 bird
Old Oct 30, 2007 | 10:06 AM
1983Fbody's Avatar
Engine: 415
Re: 4x4 bird
Boggers are raucous... Does anyone else have an urge to steal that camaro and tear up some subdivisions whilst blasting kid rock? It's just cryin' out in this Dr. Phil voice "take out that lawn ornament and mail box, drive through that white picket fence, it's okay to let your feelings out" Nice parking brake too, might come in handy the next time at a stop light and a shiney convertible bmw hood gives your camaro that snotty better-than look.
edit- So tar and feather me, other than the back bumper, I think it looks pretty neat.
Old Oct 30, 2007 | 12:03 PM
ryan91rs's Avatar
Transmission: 4L60
Re: 4x4 bird
it okay it's not really a camaro, it a berlinetta. It's the red headed step child of the camaro. it's more like a nice looking firebird. or an ugly ford.
Old Oct 30, 2007 | 03:12 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: 4x4 bird
haha, redheaded step child...ha
Old Nov 20, 2007 | 11:21 PM
imafruitcake's Avatar
Re: 4x4 bird
thats just not right
Old Dec 6, 2007 | 02:34 PM
89CamaroLover's Avatar
Car: 89 Camaro
Engine: 305 tbi
Re: 4x4 bird
I agree and disagree at the same time,
Yes it would be awesome, there aren't too many like it, a real head turner, depending on where you live would be a real chick magnet. And you could do it out of a waste of f body crappy v6 in a junk yard set for crshing. Ha Ha
but then again
WHY?
Old Dec 8, 2007 | 08:10 PM
SidepipeTA's Avatar
Re: 4x4 bird
Here are lots of 4x4 cars. http://www.jtruck.net/misc/4x4cars/
To me these are hillbillys! They all have muluts too.
Old Dec 9, 2007 | 10:15 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
Re: 4x4 bird
you dont think this is why mustang and fourth gen guys laugh at us it ?...
no really bro, do what you want just do it tastefully and clean, people will respect a professional adaptation and mechanical ingenuity over a hill!billy torchfest and budlight induced welding with a few tie wraps thrown in for good measure.
Old Dec 9, 2007 | 10:39 PM
rmmstnr's Avatar
Car: 89 TA
Engine: 305 TBI
Axle/Gears: 10 bolt 3.08
Re: 4x4 bird
Jeezum, those things look like something you'd wake up next to with a hangover, surrounded by beer cans and a welder. I suppose this is what happens when people get drunk around power tools...
Oh well, it entertains me, that's for sure, I think it's kinda cool. More! Any TA's or Camaro's converted into a 6x6? Perhaps videos? Wait-something to really make purists scream- a diesel in a 3rd gen! DUM DUM DAAAAAAAAAAA...
Old Dec 9, 2007 | 10:52 PM
quickL98's Avatar
Re: 4x4 bird
actually with all the power diesels are making today i cant imagine a duramax powered camaro being slow with some parts from banks.
look what AUDI did this year at lemans with endurance racing.
camaro + bio-diesel + 800 ft/lbs + green friendly third gens... wow! think of all the coffee shop poon you guys could score
but seriously though a duramax powered f-body would be neat if done as stated in last reply (not lifted ,just diesel) i'm thinking a dark metallic grey iroc on mesh style18's lowered just right ....
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: 4x4 bird
this thread is awsome to read but i agree go with a fiber glass body insted
Old Dec 9, 2007 | 11:34 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: 4x4 bird
Hey those lifted f-body's look pretty sick. I would never do it to my daily driver, but maybe someday I will have the time and money to lift a camaro!
As for now, here is a few ideas my buddy gave me:
Old Dec 9, 2007 | 11:49 PM
quickL98's Avatar
Re: 4x4 bird
your missing the gun rack man can you add realtree two tone also?
Old Dec 11, 2007 | 10:10 PM
TheLegedaryErin's Avatar
Re: 4x4 bird
Why don't you save your camaro for your second atempt. Find something odd ball insted like a old lincoln or fith ave. somthing you can find dirt cheep and nobody realy cares about. prefrably full frame. something that you can be knowen as the first guy who turned one of them into a 4x4
Old Dec 11, 2007 | 11:04 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: 4x4 bird
LOL
That's great...
Old Jan 5, 2008 | 05:24 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: 4x4 bird
Thats one of the funniest comments i think i've ever seen, only because i've seen it happen.
Old Jan 5, 2008 | 06:12 PM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
Re: 4x4 bird
Lol i need a backwards jesus sticker for my car lol
Old Jan 14, 2008 | 02:23 PM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
Re: 4x4 bird
I have to get in on this.....I dont think it is such a bad idea....AS LONG AS...it is done right with the tires actually somewhat in the wheel wells and it would have to have a monster engine...however I cannot see tearing up a perfectly good 3rd gen for this...the fiberglass body would be a must or like someone else said a car headed to the crusher(but i think it would be hard to find one that isnt worth saving for a orignal resto)
I know it would be nice to have an fbody to drive in the winter!!!
Old Jan 30, 2008 | 08:26 PM
  #42
Stephen's Avatar
Car: 87 GTA
Re: 4x4 bird
I used to see this truck/car (trar?...cuck?) parked on a side street almost EVERY day, her in Austin, TX. Kinda where it has gone too....
That parking lot & buildings look familiar.....I might drive over there tomorrow, and see if I can find that parking spot, just because!
Old Jan 30, 2008 | 08:59 PM
  #43
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Re: 4x4 bird
Que the Deliverance music...
Old Jan 30, 2008 | 09:43 PM
  #44
riotcow's Avatar
Car: '06 G6 GT / '85 IROC(soon)
Axle/Gears: Stock
Re: 4x4 bird
On the lines of doing it to a car no body *here* cares about, do a honda...heh
As to one nobody cares about and hasn't done, go pick up a few does kias and part them up...I'd say a few 100 would cover it
87v6Bird
Jul 1, 2018 04:12 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Trevor Tarry
Sep 15, 2015 02:04 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
