Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
91 92 tail's to 85 ta
Old Dec 28, 2007 | 05:33 PM
intruder's Avatar
i got a set of 91 92 tails today and was wondering what i need to do to get them wired into my 85 ta
Old Dec 28, 2007 | 05:37 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Re: 91 92 tail's to 85 ta
all trans am wiring harnesses are the same 4 bulbs
Old Dec 28, 2007 | 06:34 PM
intruder's Avatar
no, they are different the 85 flashes 2 bulbs for the turn signal the 91 92 flash 1 amber not sure how to make it flash 1 instead of 2
Old Dec 28, 2007 | 08:34 PM
Stephen's Avatar
Car: 87 GTA
They are not all the same. Some only use 3 bulbs, 1 1156, 2 1157s. Some use 4 bulbs, PLUS 3 smaller bulbs (145s i think).
To do my STS tail lights, I had to swap out the 2 outer most sockets to 1157 sockets. Not a big deal. Autozone/Pep Boys etc., carries brand new sockets.
Old Dec 29, 2007 | 03:13 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
i just put them on my 85 ta the way they are and the ambers dont flash
Old Dec 29, 2007 | 05:13 PM
intruder's Avatar
duh!!!what is the point of putting them on and not haveing them light up the way they are supposed to
what i want to lnow is how to modify the harness if you don't know don't reply
Old Dec 29, 2007 | 05:19 PM
intruder's Avatar
so if anyone knows let me know
Old Dec 29, 2007 | 05:31 PM
Stephen's Avatar
Car: 87 GTA
I don't know the wire specifics, but I know this...
The early wiring has no plug between the dash & the tail lights themselves,
Whereas, the 89 GTA I stripped, had a plug under under the rear seat, making it MUCH easier to unplug the harness. Dunno id the wires are the same at that point, and you could simply splice black to black, red to red, etc.
I know the early non-GTA lights & later lights have more sockets, but I dunno where the wires split off.
Old Dec 29, 2007 | 06:03 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Gentleman, here are two pics embellishing the newer harness. The connection to the main harness is behind the rear glove compartment. There are seven wires, color coded as follows; light blue, yellow, light green, red w/white stripe, dark green, black, brown....
-Rob
Attached Thumbnails 91 92 tail's to 85 ta-wireharnessrear-1.jpg   91 92 tail's to 85 ta-wireharnessrear-2.jpg
Old Dec 29, 2007 | 06:17 PM
Stephen's Avatar
Car: 87 GTA
I dunno then...Neither my 87 GTA nor the 89 GTA I parted out, and still have the harness from that I was referring to above, have the connector in your pics.
Old Dec 29, 2007 | 06:23 PM
^ It's been awhile since I seen an earlier harness. He'll either need the pigtail running from the fusebox along with the piece that I posted, or he'll have to match up the '85-'92 wire for wire and solder them accordingly. Steve, how many wires run toward the back with the earlier harness....?
-Rob
Old Dec 29, 2007 | 06:37 PM
intruder's Avatar
sounds like alot of bs i may just sell the lights instead, i won't hack up the harness in my car for nothing, the harness in my 85 is from a 89 so the plug is flat and plugs in beside the rear seat the 85 harness plugs in in the rear compartment and the 91 92 plugs in behind the rear glove box dr side i know where everything plug's up i need one that plugs in by the rear seat 89 firebird should do it
Old Dec 29, 2007 | 06:39 PM
^ No problem man, if you ever change your mind, lemme know....
-Rob
Old Dec 29, 2007 | 11:04 PM
Stephen's Avatar
Car: 87 GTA
-Rob
Here ya go...My 87 was basically the same way, but there was no connector under the rear seat. The only connector is under the dash, then it goes AL THE WAY back to the lights.
89 GTA Tail Light harness
Close up of the main connector under the rear seat
I can go through thhe haness, to see which of the 6 wires go where.
Old Feb 28, 2008 | 11:32 PM
Hunnicuttz's Avatar
Car: 1992 Formula
Engine: 5.7 350
I have a 92 and I want to put the 82-84 tail lights on my car. Has anyone here done this? Will I be able to wire the old 82-84 wire harness into my 92 harness?
Old Mar 2, 2008 | 08:35 PM
skitztikwon's Avatar
why is yours a ta
Old Mar 2, 2008 | 09:49 PM
Hunnicuttz's Avatar
Car: 1992 Formula
Engine: 5.7 350
I am doing a knight rider conversion and I want to put in the old tail lights. Mine is a formula
Old Mar 3, 2008 | 08:11 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Converting tail lights isn't as easy as you would think. I thought it was when I converted my old 89 formula to an 86 TA light. Trans Am lighting is different than any of the other models even in the same year. Here is the problem I ran into with switching to the TA tails.
The difference is in the brake switch. When you step on the brakes a switch allows voltage to be sent to the tail lights. The voltage is sent to two different places. On the TA the voltage from the brake switch goes to the turn signal switch. This is where it will get a little complicated. On the formula the voltage bypasses the turn signal switch and goes straight to the tail lights.
Sometimes the same bulb is used for multiple functions. So if voltage is routed incorrect then all kinds of weird things happen. Like what you ask? Well when i stepped on the brakes my horn would sound. HAHAHA!
Old Mar 3, 2008 | 08:24 PM
Hunnicuttz's Avatar
Car: 1992 Formula
Engine: 5.7 350
How did you get it to work?
Old Mar 3, 2008 | 08:32 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
You need a wiring diagram for your car and for the car that the tail lights are from. Then find a taillight harness with a male and female connector and start splicing wires where they need to go. Color coded wires are your friend!
Old Mar 3, 2008 | 08:50 PM
Hunnicuttz's Avatar
Car: 1992 Formula
Engine: 5.7 350
Haha this is not going to be fun, I'm colorblind haha. Where did you find the diagrams?
Old Mar 3, 2008 | 08:59 PM
Stephen's Avatar
Car: 87 GTA
FYRCHKN did his. Wasn't that hard, switching over to GTA lights o hie 91 Formula. A simple 5 min wire change under the dash, and the Formula lights will work just like GTA lights.
Then, during the Super Bowl, a STS controller was installed on his lights.
Old Mar 3, 2008 | 11:16 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Which wire did he change that only took five minutes. I'm interested because mine wasn't that easy. If i did it incorrectly or if their is a better way to do it than I would be interested. I hate taking the long way around when there is an easy fix. Let us know the exact details how he did it. Thanks.
Old Mar 3, 2008 | 11:22 PM
Stephen's Avatar
Car: 87 GTA
ATGO
Old Mar 4, 2008 | 11:15 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Wow, I have been polishing my 91-92 Trans am taillights and was going to start researching this topic. I thought it was going to be a fairly simple installation. I know people have done this, why are things getting so much more complicated then they should be??
Old Mar 4, 2008 | 01:28 PM
Hunnicuttz's Avatar
Car: 1992 Formula
Engine: 5.7 350
Wow thanks for the great link!
Old Mar 4, 2008 | 01:44 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Its easy bud give me a call. I lost my old cell n a glass of milk.. so I dont have your number.
Old Mar 4, 2008 | 05:40 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
I wouldn't trust Mr. Milk Cell Phone with my car. J/K
Old Mar 4, 2008 | 06:24 PM
intruder's Avatar
sold the tails the other day
Old Mar 4, 2008 | 08:08 PM
Engine: 388 Carb
Axle/Gears: 4.10
I see people on ebay fetching close to $500 for a perfect set, which is what mine is.... im tempted to do that but i reallllllly want them on my car for a little bit.
Old Mar 4, 2008 | 08:16 PM
Stephen's Avatar
Car: 87 GTA
Yeah. I have an extra set of GTA tail lights, and I've had good friends begging for them. But if I ever need a set, I can only imagine what I'd pay, besides with every day that goes by, they'll get harder to find, and the asking price will go higher.
Old Mar 5, 2008 | 04:57 PM
intruder's Avatar
they went in the garbage can actually, couldn't give them away
Old Mar 5, 2008 | 09:30 PM
Engine: 388 Carb
Axle/Gears: 4.10
I am assuming that you are talking about the 3 part 85-90 taillights...
I am talking about the 2 part 1991-1992 TA/GTA taillights. Those go for big money and are the ones I am trying to wire into my 88 Formula.
Old Mar 6, 2008 | 03:04 AM
intruder's Avatar
nope they were the 2 piece
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
