Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
modified iroc hood????
Old Jan 1, 2008 | 09:37 PM
86irocterror's Avatar
i need some input from everyone here. the engine i think im going to be putting in my 86 iroc will not fit under the hood. i think the stock hood looks best on the car and hate to change it at all but ive been thinking about doing some cutting and welding of the stock hood to change it into a cowl hood. i would be cutting along the stock lines on the top of the hood and raising it up gradually from the front to the back. im not positive on how much i would need to raise it but im guessing 2 inches or so. i wouldnt go any higher then i need to to get it to fit. anyone done this before? if so how does it look? and what does everyone here think it will look like? im good friends with a guy who does all body work and what i cant do he can do for sure. he does old rods and stuff for people so the work is not a problem for me and would be done right!!!!! thanks in advance for the input everyone!
Old Jan 1, 2008 | 09:52 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: modified iroc hood????
do a search for the iroc daytona hood, its just like what your talking about.
Old Jan 1, 2008 | 09:57 PM
ruberbanman126's Avatar
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
do u mean a hood like this one, its called the jongbloed hood.
Old Jan 2, 2008 | 01:10 AM
ive seen the daytona hood and do not like it with the vents on the side. and i like the jong bloed hood but heard its discontinued
Old Jan 2, 2008 | 01:20 AM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I'd personally think you could take a daytona hood to someone who is good with fiberglass and have those side holes filled in, dont know too much about this though. I just checked, doesnt look like hawks has the jongbloed hood, but gt fiberglass does (check their feedback before buying from them). hawks does have something though, the "sunoco" style hood, it looks pretty similar to a jongbloed.
Old Jan 2, 2008 | 02:46 AM
83 Crossfire TA's Avatar
Do a search, raven something or other (sorry, forgot the name) from Australia did something similar with a stock hood a few years ago. I think he ended up not liking what he ended up with and went with something different.
Old Jan 21, 2008 | 07:44 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
like this? Not mine but saved it off this board long ago...
Old Jan 21, 2008 | 08:22 PM
85maroz28's Avatar
or...
Old Jan 21, 2008 | 08:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Cowl scoop grafted to a factory fiberglass hood and a short aero scoop attached to the top of that.
Old Jan 22, 2008 | 05:48 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I love that hood. With my luck it's probably a custom hood that someone made isn't it?
Old Jan 22, 2008 | 11:18 AM
85maroz28's Avatar
I believe so... Here is the post I found it in. https://www.thirdgen.org/forums/body...rted-cowl.html username:crazycrocket
Old Jan 22, 2008 | 12:00 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Here is my still not fully installed Daytona Hood 2.5" cowl. Came with holes already drilled out from www.HAWKSTHIRDGENPARTS.com
Old Jan 22, 2008 | 12:02 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I'm liken the cowl iroc hood! Has anyone installed z28(late) hood blisters on the jongbloed hood yet? Might look sweet!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
PestilenceIV
Aug 20, 2015 02:33 AM
mustangman65_79
Aug 11, 2015 03:17 PM
