Bubbas loose at the Walmart in his 4x4 Bird
Car: '89 5spd GTA
Engine: 305(LB9) TPI
Axle/Gears: Borg-Warner 3.42
Saw this at Wally world in GA this weekend. Looks like it was done correctly with fancy shocks and all. Poor girl
Car: 91 Camaro RS
Re: Bubbas loose at the Walmart in his 4x4 Bird
haha wow.. the head lights look like sad eyes. It does look done right just not so much a good look for the car (in my opinion).
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Maybe I should turn one of my DT500's into one but my 85 silver 4X4 is a long bed. I will just have to stretch my 78 Cutlass and make it fit. Hold on there, I think I'll just leave it as a truck.
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
It's the unholy spawn of a bronco and a screaming chicken. And maybe a frog thrown into the mix...
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
No It just proves the media wrong. with all the controversy with big chain stores destroying our towns... It just shows Walmart clearly has it's loyal customers.
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
this birds the ugly duckling but seriously that thing is pretty cool it just aint right in no way shape or form, and the worst thing is i bet that was a really clean car before this
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
he just need to put some antlers on front and a shotgun rack on the hatch glass
Car: 1984 Camaro Z28 T-tops
I'd love to do that to a wrecked Camaro. Wouldn't rip apart a good one to do it though. I agree though, that Firebird does look sad.
Car: 1990 Camaro RS
Engine: L03 305 TBI
I've always wondered if I could fit a 4wd setup under one, and keep it stock looking. Add some power and spend some money on the transfer case/trans and you may be onto something.
I don't think it would fit very well under the floor. Trucks have a frame they can throw a t case between, F-bodies don't. Read another thread about this, they were saying that maybe you could take a similar wheelbased truck and hang the Camaro or Firebird body around it.
Car: 1987 pontiac firebird
Engine: a 455
Transmission: dont know im not a mechanic
Axle/Gears: dont know im not a mechanic
that would be illegal to drive in my area
Really an AWD one would be better,the 4wd wouldnt serve much of a performance (go fast, race) mod. THe lack of ability to launch it without possibly damaging something on the dry pavement.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Im pretty sure if you are lifting a firebird on like 35"s, the last thing you plan for it is "going fast and racing," all you are gonna want to do is bog, bog, and more bog.
Engine: LO3
I will give it a good home - about 10 miles into the powerlines, sunk in the mud!
Car: 1979 Zcode TA
Engine: 220hp 400ci Building a EFI 455
Transmission: 4 speed
could you imagine what the investment redirected into some normal restoration or modifications would look like? To each is his own, but I would like to have the funds spent on that directed into my project car.
Engine: LO3
Those cars are probably alot less of an investemnt than you think...
If you watch the local craigslist, you can find cheap solid body f-cars with a blown motor, or something, for less than $500 all the time. Then, you can also find cheap K5 Blazers or K10 pickups with 4wd, solid front axle, for just as cheap, with rotted bodys. Take the frame off the truck, body of the car, and use some rhedneck welding / fab skills, any scrap metal you have lying around the yard, and alot of beer, and you end up with a 4wd camaro for cheep...
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
You would have thought that after all that work to make it a 4x4 they would have at least fixed the headlights so that they close.
Such a travesty. I am a Pontiac man at heart, but I am a muscle car fan overall. Yesterday I saw this done to a 71 Challenger. I almost cried. Stop it people. The factories made them this way for a reason.
