Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fuel cell
Old Jan 31, 2008 | 06:13 PM
texan_rebel's Avatar
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
fuel cell
i did a search and found a couple of pics with fuel cells not many though, i seen this kind of fuel cell
http://www.jegs.com/webapp/wcs/store...10002_72978_-1
but i was wondering if you could do it with this one in the lugguage compartment?
http://store.summitracing.com/partde...5&autoview=sku
i am going to be running a carbed 350 most likely with a mech. fuel pump, i thought you pretty much have to have a sump on the cell or am i wrong
Old Jan 31, 2008 | 07:58 PM
Travis&camaro's Avatar
Car: 1984 Camaro
Engine: BIG BAD 360!!!!
Transmission: th350 shift kit 3600 stall
Axle/Gears: 3:73 posi
Re: fuel cell
Im putting one in right now. I baught a 12 gallon Jaz with a sump. I cut a squar hole in the front of the luggage compartment and put it in so the top of the cell is about a in below the sheet metal on top of the carms axel thats flat. And im using angle iron going from side to side on the car to make every ting sterday. I havnt decided on what Im doing for a fire wall yet either.. Does that fuel cell have a sending unit?
Old Jan 31, 2008 | 09:43 PM
Car: 1989 RS camaro
Engine: 350Ci
Re: fuel cell
Let me know how that goes, i believe both tanks have gm sending units, do you know if you have to have a sump for a mech. fuel pump?
Old Feb 1, 2008 | 03:25 PM
Car: 1984 Camaro
Re: fuel cell
YOu dont have to have a sump for mechanical fuel pump.. Im running a 140gph electric..
Old Feb 4, 2008 | 07:41 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: fuel cell
i have the rci one and it will not fit in the luggage compartment without modification. ie cutting and welding. the bottom is smaller then the top of the compartment so the fuel cell starts to go in fine then it will stop about halfway.
Old Feb 5, 2008 | 06:04 PM
Car: 1984 Camaro
Re: fuel cell
I pritty much have mine in. Im trying to add a pic but it wont let me dran dial up Ill send you a picture and you can post it if you want.
Travis
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
colton_carlson
Mar 8, 2019 12:21 PM
89fast5oh
Sep 27, 2015 09:04 PM
92camaroJoe
Aug 13, 2015 06:07 AM
