Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Roll bar install questions
Old Jan 9, 2008 | 10:55 AM
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
okay so i got the interior of my car all torn apart, ready to install my roll bar. but when i put it in, it's touching the headliner at the corners.
do i just cut it down, or leave it?
if anyone has pics of nice looking roll bars in cars, please post'em.
also i'm looking for ideas on where to mount the rear struts for the hoop.
thanks.
Old Jan 9, 2008 | 10:57 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: Roll bar install questions
how badly is it touching the coners? like it wont fit type of it will fit but its crushing the headliner?
Old Jan 9, 2008 | 11:06 AM
Car: 1992 Z28 1LE
it fits in the car where is supposed to, but it's just touching the headliner. like it's not crushing the headliner. i just think it might be better if there was like a half inch gap or so. this is the first cage i've done. it's a competition engineering main hoop so i don't know if i should cut it off or not.
Old Jan 9, 2008 | 11:09 AM
joshh44's Avatar
Engine: engineless
i never installed a roll bar before.
you could cut the bottom of the main hoop an inch or so off and reweld the plates on them.
that would help clearence. or you could leave it the way it is. or make a custom headliner.
Old Jan 9, 2008 | 03:39 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
My hoop is tight against the headliner, maybe 1/4" gap at the most. You want it to fit as high as possible inside the car. And since you'll be doing welding to the top of the hoop for the back bars....why is the headliner in the car anyways?
Old Jan 9, 2008 | 03:53 PM
afida15's Avatar
im thinking of a roll bar myself, more for looks purpose though, cuz i dont really need one but i like the look of them. whats a good fitting roll bar kit? ive seen the ones on like jegs and summit but do they fit ok?
Old Jan 9, 2008 | 08:18 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
i have a comp. eng. 8pt and the directions said you need to cut it to size. i couldnt even get mine to stand straight up in position because it was to tall.
Old Jan 9, 2008 | 08:41 PM
xpndbl3's Avatar
Car: 1984 Z28
i have the comp engineering kit as well and every pipe had to be cut to length, but that's for all the different angles you can run on a roll bar.
Old Jan 9, 2008 | 10:21 PM
car_fixer's Avatar
you want the bars as high as you can get them and still get the trim and head liner back in, you need to have the bar above your helmet sitting in the seat. I custom made this cage, and it is close, about as close as you can get and still weld it
Old Jan 9, 2008 | 11:24 PM
Car: 1992 Z28 1LE
good deal. that last pic is exactally how mine fits.
mine is a comp. eng. bar too, but i just boght the hoop and i made the strut kit myself. they wanted like $150 for it from summit ans the local steel yard charged me $31 for a 20 foot bar.
Old Feb 5, 2008 | 09:38 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
That is really cheap for that 20ft bar. Is it thick enough? Rolled or DOM?
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
