Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
i need ideas and pics on how to make a nos blow shieald
Old Mar 30, 2008 | 10:05 PM
badass91's Avatar
i have an 86 iroc and im putting nos in it and for the track i need a blow shieald any pics or ideas thanxs
Old Mar 31, 2008 | 08:56 PM
sixpackmtrspts's Avatar
Re: i need ideas and pics on how to make a nos blow shieald
never heard of a blow sheild. you do need a tube connected to the blow off on the valve that vents outside of the car if the bottle is mounted in the passenger compartment.
Old Apr 2, 2008 | 11:16 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
I was beginning to think that I had missed something.... I have never heard of a "blow sheild" either.....
Kevin
Old Apr 3, 2008 | 06:27 AM
TheRealBlkBird's Avatar
Car: Pontiacs, Jeeps
wtf is a blow shield?
Old Apr 3, 2008 | 09:55 PM
badass91's Avatar
i was told i need one i guess its like a wall between the bottle and the engine compartment
not the engine compartment the passenger compartment
Old Apr 4, 2008 | 10:25 AM
Kwik89GTA's Avatar
Never heard of such a thing. Nitrous bottles must have a vent tube (vented outside) if they are mounted in the passenger compartment. Other than that, I have no idea about a sheild........
Kevin
Old Apr 4, 2008 | 11:08 AM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Nos can be mounted in the car next to the driver without any type of firewall or shield. They are right about the blow down tube. Due you mean a burst panel? Not needed for track.
Old Apr 4, 2008 | 10:12 PM
badass91's Avatar
ya a burst panel thanks so i dont need one thanks alot guys all i need is the blow down tube? also do i have to weld the bottle bracketts or nut and bolt ?
Old Apr 5, 2008 | 05:49 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Some of it will depend on what bottle you have. Which kit did you buy, and what bottle does it have?
You need something like this....
http://store.summitracing.com/partde...5&autoview=sku
then you need a blow-down tube. The tube attaches to that fitting, and the tube must vent to the outside of the vehicle.
You can use can bolt the bottle mounts down that is fine, you just have to make sure they are "secure". When I tech my car, they usualy just pull/push on it a bit, and make sure it won't go anywhere.
Here is how I have mine mounted, I drilled a hole in the pastic behind the seatbelt, and then the blowdown tube exits the car through the spare tire well. I had to do a little bit of bending on the tube to make it fit like I wanted, and I cut about 5" off the tube so it didn't hang down that far.
Hope that helps.
--John
Old Apr 5, 2008 | 06:20 AM
badass91's Avatar
thanks that helps alot
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
BurlyChev
Aug 16, 2015 09:08 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
