Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
t-top keys
Old May 20, 2008 | 11:40 PM
North's Avatar
Car: 1986 Camaro Z28
Engine: 400 chevy small block
Transmission: 5spd
t-top keys
wasn't sure what section to put this in....
I have searched all over but can't find and real info. I need to know if they make any after market key replacements for t-tops. is the drivers door key supposed to fit? mine doesn't and i want to make sure i can lock my t-tops...
can a locksmith do this or is it a easy 10 min job that i could do if i had the parts?
any info appreciated
Old May 21, 2008 | 12:17 AM
wolverine350r's Avatar
Car: 91 TA WS6
Transmission: Auto :(
Re: t-top keys
I had a 91 and the door key did it. If yours doesn't match it, I bet you can take the tops to a lock smith and they can make one - they did it for the ignition on one of my old cars.
Old May 21, 2008 | 08:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: t-top keys
When I swapped my glass tops for some Lexan ones, I changed the locks so my key would still work.
Old May 21, 2008 | 10:05 PM
North's Avatar
Transmission: 5spd
Re: t-top keys
ok sweet! I really wanted to know if the door key was supposed to work. i bet mine are from a different car then. i'll c what i can do with the lock smiths
thanks
Old May 22, 2008 | 12:10 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: t-top keys
Door key is supposed to work, but I've found some of the locks are keyed for ignitions. You can buy a new lock set from Hawks, or ModernDayMuscle, etc. etc. and it might be cheaper, as when I got quoted locksmiths to just rekey the cylinders, they wanted $15/lock even if I brought them completely disassembled locks.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Gunner242
Dec 25, 2015 04:49 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
