Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Still searching, anyone got some pics of fab'd dual pipe intakes?
Old Jun 17, 2008 | 02:36 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Im planning on relocating the battery to the trunk and running dual 3" pipes for my intake. I know I've seen some, but I was wondering if some of yall have some stored on your PC somewhere. I assume I could just make 2 seperate CAI, one going to the pass side and one going to driver side, and then just cut the pipe in half at an angle at the TB and weld the two pipes together. Is this making sense? Im gonna keep looking, but everything Im seeing is Home Depot CAI, I want something a little cleaner looking. Gonna polish all the pipes and powder coat them with candy red to match the rest of the accents
Old Jun 18, 2008 | 08:25 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Still searching, anyone got some pics of fab'd dual pipe intakes?
^ Like This?
Old Jun 18, 2008 | 08:31 AM
spills's Avatar
Car: 89 RS
yea, similar, but hard piping is what Im looking for. I know for a fact that Ive seen at least one on here, but I wanted to get a better look at it. I think the only thing that I would change as far as the picture you posted would be to seal off the filters, and make it out of 3" exhaust piping
Old Jun 18, 2008 | 08:49 AM
^ There's actually one for sale here (the one that I posted), Click Here. I agree though, I know I seen a custom polished one somewhere, just can't remember where....
Old Jun 18, 2008 | 09:27 AM
Could only come across one for you (and it's one of those cheapo, Home Depot designs), maybe someone else has some better quality images.....?
Old Jun 18, 2008 | 09:29 AM
spills's Avatar
Car: 89 RS
ya, Im still searching for it. Im not looking to buy anything, just looking for some ideas on how I can fab up my own. main thing Im trying to figure out how to do is mating the two pipes up at the TB. I know once I get out there and start cutting up the piping it will come together, but I also wanted to see how other people ran theirs, and if they used 3" piping or stepped it down to like 2.5" (being dual intake, I assume dual 2.5" into a single 4" pipe at the TB shoudl be sufficient)
Old Jun 18, 2008 | 10:33 AM
grthrawn's Avatar
just buy a set og 3" polished intercooler pipping from ebay. its under a $100 and go to home depot and but a ruber 3" t fitting
also what kind of motor is this going on? im running a carb set up, i grabbed a top hat from a 97 4.3lvortec blazer so i connect the pipping straight to that.
Old Jun 18, 2008 | 10:39 AM
spills's Avatar
Car: 89 RS
I can do the polishing and powdercoating myself. What Im looking for is just a picture of how others have created theirs. I know how and where to get the materials
Old Jun 18, 2008 | 01:09 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
have you tryed searching for twin turbo setups. I remember some of them have 2 tubes into 1 at the tb.
Old Jun 18, 2008 | 02:34 PM
spills's Avatar
Car: 89 RS
no, actually. didnt even think about that. Ill give that a shot too
Old Jul 29, 2008 | 01:07 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Spectre Performance sells CIA kits and individual components- you could just buy the Y-connecter from them and fab the rest...
Old Jul 29, 2008 | 02:02 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
A dude I knew years back had this done at an exhaust shop.
http://www.cardomain.com/ride/2263729/5
Old Jul 29, 2008 | 03:45 PM
1986 z28's Avatar
Car: 1986 z28
Engine: 350 block.11.0 to 1 comp .638 cam
Transmission: 700r with a 3800stall,shift kit ect
Axle/Gears: 4.10posi 10 bolt
this is a 4 inch set up from specter,its nice because you have alot of flexablity with all the stuff they sell. wat i have here was about 180 with a filter.check them out,i kno jegs sell their stuff
Old Jul 29, 2008 | 03:46 PM
1986 z28's Avatar
Car: 1986 z28
i kno its on a carb but u get the idea
Attached Thumbnails Still searching, anyone got some pics of fab'd dual pipe intakes?-0722081441.jpg
Old Jul 29, 2008 | 09:16 PM
jonarotz's Avatar
Car: 91 Z28
This is how I did it on my twin turbo setup. Pretty easy too. I don't know if you are able to weld or not but this is an example.
Attached Thumbnails Still searching, anyone got some pics of fab'd dual pipe intakes?-dsc07630.jpg
Old Jul 29, 2008 | 09:19 PM
spills's Avatar
Car: 89 RS
/\ I like that! I wouldn't have to relocate the battery that way, only thing I might do different is try to merge the two pipes into one 3.5" or 4" pipe instead of having them come together right at the TB.
BTW: Sick lookin motor!
Old Jul 30, 2008 | 10:13 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
sick looking setup jonarotz... wat size turbos are those? i was thinking of doin a twin turbo for my HSR 383 and was gona get a set of T3's bc there cheap but T3/4's hybrids would be better... but i think the T3's are too small. wat boost u running and hp #'s!!! who tuned it
sry didnt mean to hyjack the post.
spectre sells a kit that runs dual pipes tho. if u can weld get sum 3" exhuast pipe and make it work and relocate the batt or run dual tubes down the side of the motor and down underneith the front of the cam and setup a ram air setup maybe...
Old Jul 31, 2008 | 07:44 AM
jonarotz's Avatar
Car: 91 Z28
custom,
Thanks for the compliments! These are the turbos I am running:
https://www.thirdgen.org/forums/engi...o-gt-66-a.html
I am only running around 7 psi, mostly around 5psi. I need to get a boost controller cuz my wastegates are cracking open and bleeding off some pressure. I usually hit 7 psi at 5-5.5K rpm. I am doing my own tuning with a Gen 7 DFI setup and currently it is making close to 500hp at the wheels.
Old Nov 14, 2008 | 03:13 AM
sketchy's Avatar
Engine: 355 carbed
Transmission: 4 speed!
Axle/Gears: 3:23 Welded!
heres pics of my cai, went to junkyard and took a tbi parts and tubing, its pretty self explanitory, it gets the air from the lights and goes into a k&n
Old Nov 14, 2008 | 08:36 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
EPIC I use to do that on my vega on autoX days. Great work on this bit of creativity.
Old Nov 15, 2008 | 02:00 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
sketchy, thats a pretty clean Fresh/ram-air setup. It's harder to do with a TPI setup, because the TB is so close to the radiator/core support.
Old Dec 16, 2008 | 09:40 PM
gunner53227's Avatar
Car: 86 TRANS AM
Transmission: 700 R4
Axle/Gears: 10 bolt/3.73
That's a pretty cool idea!
Old Jan 11, 2009 | 06:18 PM
georgealtemus's Avatar
Car: 1987 gta trans am
Engine: 5.7l 350 supercharged and more
Transmission: 700r4 w/shift kit
Axle/Gears: moser 12 bolt w/373 aubern posi
Sick motor.Do you have any other posts with more pics of youre setup?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Bstrang6
Aug 26, 2015 11:39 AM
