Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Targa top conversion.
Old Jul 12, 2008 | 07:18 PM
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
okay so tell me if i am completely insane for wanting to try this. i want to have a real targa top camaro when the project is finished. so i am planning on making a very thin frame to go around the edge of the glass on the t-tops, then latching them in place, brake the glass out of them, then weld the frame of the t-top to the center "t" bar in the body. then get inside the car, and cut that bar out of the car with the plasma cutter. then un latch the t-tops, then when we lift the tops of, they will come off in one piece with the center bar. aka a targa top??? and i'm not worried about the body flexing, because the car has weld in subframe connectors, and a roll bar with door bars, and rear bars, and i have a bar going from the firewall to the front subframe.
then i'll worry about the headliner once that comes into play at a later date. then i will lay some fiberglass over the t-top frame just to make it smooth and paint-able. and i think with a lil grinder action, and welder action, we can even get a seal in there to make the whole thing seal up when it rains.
i was just wondering if anyone has already done this, or tried it and failed. any input will be aprecciated.
Old Jul 12, 2008 | 07:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Targa top conversion.
its been discussed a few times, never seen a car with it done. The biggest issue is getting glass for the targe top and custom weather stripping.
Old Jul 12, 2008 | 08:27 PM
Car: 1992 Z28 1LE
i was going to do a fiberglass targa top, and there is a boat shop in portland that says they can come up with a weather strip.
Old Jul 12, 2008 | 10:01 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Old Jul 12, 2008 | 10:05 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Now i dont know if you would want to try this but what if you got the targa top from the supra or even some corvettes where you could just use their glass and set it up with their measurements.
kevin
Old Jul 12, 2008 | 11:52 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
A targa from a C3 Corvette maybe what will work for a thirdgen. If you want to do it right, just do a Google search online for someone that does this custom work for a living.
You are swimming upstream with this one. I have seen the targa conversion done to a few Z06s both C5 and C6 but the targa off of a C4,C5 and C6, will not fit the thirdgen because it is only flat on one side and covers the roof in the front. The C3 targa maybe the trick but good luck finding one. Looks like it's going to be lots of Google searching for you! Good luck and let us know how it turns out.
Old Jul 13, 2008 | 07:07 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Back in '84 I saw a then new T/A at a dealership with a targa conversion done to it so back then it was available but not a factory option. The removeable piece wasn't glass and was covered in a black vinyl so I'm guessing it was either some form of plastic or fiberglass panel.
Old Jul 13, 2008 | 08:47 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
I'm assuming your talking about a aftermarket one-piece astro top for a C3 corvette because all the C3's I've ever seen were T-tops from the factory.
I currently have a astro-top on my C3 and it will not work on a 3rd generation F-body.....two totally different designs. The 68-82 Corvette has a rounded shape at the front and the 3rd gen F-body is more squared off.
Here is a picture of the one-piece top when I first bought it. It's made of acrylic and somewhat flimsy, but works in my application because my t-bar is still there.
The dimensions are no where near that of a 82-92 Camaro/firebird
Old Jul 13, 2008 | 09:10 AM
KITTvsKARR's Avatar
Car: 02 WS6, 83 WS6, and 78 Project
Engine: LS1, LG4, and 400
Transmission: 4L60E, T5, and TH400
Axle/Gears: 3.73, 3.73, and 2.73
This is something I've always wanted to do with my 3rd gens.. HATE that damn middle bar.... but haven't been able to find a place to make the top..
Old Jul 13, 2008 | 09:58 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
do a search for targa top on this site. you will find where I did it and talked about it.
I'll put it here also so people who only find this post see it also.
Its an easy job to do if.
#1 You have some basic welding,cutting,measuring skills.
#2 You can do good figerglass or lexan work.
#1 thing to do is put in some weld in subframe connectors. IF you dont have em. Dont even think about cutting the T bar out yet. I had em in mine already and you could still feel a little give when the t bar was finally removed.
Id sugest a 6point roll cage to really stiffen it up. You can put a nice cage in and out of the way it wont bother you in a daily driver if your worried about that. Put the door bars low. and make the hoop cross bar removable if you have people who ride in the back.
When you take the headliner off you will see all the stop welds.
Some pic's here
http://www.cecoatings.com/images/CarStuff/92Z/Targatop/
Once you drill out the spot welds you will have ot make a few cuts. DO NOT cut the little metal in the front or back flush. You have to roll a l ittle lip over . You will see what Im talking about.
As for the top. Thats what takes a little work. Find a extra set of t tops. use the ends for your main section just like a stock set. If your good with composits or lexan you will know what to do. No need for me to goingto all that.
It can be done. Just take your time and do it. I would have liked to finised mine off but I picked up a totaled vert and took it a step further and went from
T-Tops ------> targa --------> vert.
http://www.cecoatings.com/images/CarStuff/92Z/92Z28.jpg
http://www.cecoatings.com/images/Car.../targatop5.jpg
http://www.cecoatings.com/images/Car...s/DSC02741.JPG
Then off to the scrap yard.
http://www.cecoatings.com/images/CarStuff/92Z/ouch2.jpg
http://www.cecoatings.com/images/CarStuff/92Z/ouch1.jpg
Old Jul 13, 2008 | 11:03 AM
^ Everybody who wants to do this needs to take note of what Chris is saying, he's been there and done that, and knows exactly how to make it look like a factory setup. Also, did nobody see the picture that I posted, in the background under the tree? They simply used the sides of the T-Tops fasteners and made one long piece using plexiglass (look in the background, by the tree). Here's another pic that I have saved of a similar concept using the T-Top method as reference points....;
Old Jul 13, 2008 | 12:05 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
thats the old simon and simon car for the TV show..
here are more pic's. I posted for TGO back in '04
http://www.cecoatings.com/images/oth...RO/forTGO1.jpg
http://www.cecoatings.com/images/oth...RO/fortgo2.jpg
another one someone did. There are finished pic's on TGO somewhere
http://www.cecoatings.com/images/oth...A/dsc_0673.jpg
Old Jul 13, 2008 | 04:18 PM
Guro 305's Avatar
Axle/Gears: Stock
Like I said, MAY work. Not WILL work.
Custom job is the way to go.
Old Jul 13, 2008 | 05:09 PM
Then what about the supra it looks like it might be more simple.
kevin
Old Jul 13, 2008 | 06:28 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
your making it harder then it sounds.
Adapting one form a different car will be 10x a PITA then just making a new peplacement for the glass ones of the T Tops.
Old Jul 13, 2008 | 10:14 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
What will you use for seals?
Old Jul 14, 2008 | 07:41 PM
Car: 1992 Z28 1LE
see that is exactally what i am going to do. i already have subframe connectors in place, the main hoop, door bars, and rear struts, and a spare set of t-tops. looks like this weekend will be fun!
Old Sep 15, 2008 | 01:54 PM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
Update?
Old Sep 16, 2008 | 10:21 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Street Lethal, is that your ride? Do you have more pics of it ?
Old Sep 16, 2008 | 08:48 PM
Pocket's Avatar
Car: 91 Trans Am
Its not his
It was a cali dealer conversion sold on ebay a few years ago
Here are the pics I saved from it
http://s150.photobucket.com/albums/s...4/Targa%20GTA/
Old Sep 17, 2008 | 09:20 AM
Car: 1987 IROC Z
Nice, this one will definitely go in the gallery. Is this person a member of TGO ?
Old Sep 17, 2008 | 11:27 PM
Pocket's Avatar
Car: 91 Trans Am
Not that I know of
Old Feb 25, 2009 | 02:43 PM
cobrajet69's Avatar
Car: 88 IROC
Engine: ZZ4, Fast Burn Heads
I was doing some searching in google and ran across this page. I haven't searched this site for any more info on this subject but wanted to ask if you converted this car yet?
My brother is working a deal to get an `83 Camaro with a dealer installed Targa top and I was just curious if they worked ok or if they were a PITA. It's a 2 owner car and is supposed to be in pretty good shape.
TIA,
David
Old Feb 25, 2009 | 03:33 PM
Car: 1991 RS Camaro
Targa top conversion or T-top conversion?
Old Mar 8, 2009 | 04:40 PM
mfaust's Avatar
Car: 88' Trans-AM WS6
Im considering doing mine, any update? Did you do it?
Old Aug 14, 2009 | 01:23 PM
confucius101's Avatar
UPDATE???????
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rsrookie
Sep 5, 2015 07:08 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
