Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Brights Go Out ( Help )
Old Sep 2, 2008 | 06:47 PM
Jokerslye's Avatar
I don't know if this belongs in this thread but here is my problem/
I own a 1986 Iroc-Z28 Camaro , When I drive down the road at night I have to have my brights , The regular lights just do not provide me with enough light so I turn on my brights. I turn them on and bam works perfect but then If they stay on for too long they blink and blink and then go completely out and the only way to get them back Is if I go back to my regular lights and wait a few minutes then turn my brights back on , I have to do this a few times.
I just replaced the Windshield Switch **** thingy paid 40 bucks for it and its brand new , I was told that would fix it but I just expierenced the same problem again and I have no clue what it could be ? Anyone have any ideas at all please?
Old Sep 3, 2008 | 01:16 PM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
Re: Brights Go Out ( Help )
check the power to the relays for you headlights you may have a short in the high beam circuit or the relay may not be functioning properly
Old Sep 3, 2008 | 05:46 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Your brights switch may also be bad. I had the same problem with my '86. It was almost like the switch wasnt enguaging and staying on like it should. They arent hard to change. It might help if you drop the column. just another suggestion.
Old Sep 4, 2008 | 11:00 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
More than likely it is the dimmer switch mounted down on the column, if it is the problem there will be some blackened areas more than likely to let you know. Also make sure that it is tight to the column and adjusted properly. I have worked on cars when guys replaced them and didn't adjust them properly and would go between high and low beam by adjusting the tilt.
F-body-fan
Jan 12, 2023 01:49 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
dbrochard
Sep 25, 2015 04:56 PM
gta_knight
Sep 17, 2015 03:48 PM
louishenry
Aug 28, 2015 09:41 AM
