Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Good 110v Wire Feed???
Old Sep 7, 2008 | 07:14 PM
1986Sleeper's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
Not sure if this is the right area to post, but Im looking to get a cheaper 110v Welder. I have a 230v welder at work but it a paint to bring the car there everytime. Looking to do body panel welding, and at most 1/4" thick.
Looking for someone who has, or has used one. and how it worked/
Old Sep 8, 2008 | 09:25 AM
83TransAmRECARO's Avatar
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
Re: Good 110v Wire Feed???
a good 110 welder... not really sure they make one... I've used a few of them, I used a lincoln 110 mig and it done great... worked fine on body panels and if I remember right the guy spent about the same as a 110 arc costed... I've used a cambell housfield 110 arc and it was junk... couldn't even get it to penetrate properly... also used a ch mig and it worked ok... but not as good as hoped... maybe that will help... thickness' ranged from 1/8 in. to about .030 thick...
Old Sep 8, 2008 | 11:44 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
, the lincoln 110v mig works very well, i have one, exhaust is no problem with it, i havent done much else yet
Old Sep 8, 2008 | 12:08 PM
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
Looks like I will be shopping for the Lincoln MIG.
Im not looking to do any heavy work. I will use the good one at work for that. But over the winter I may weld in a new quarter, and exhaust and other misc. things.
Thanks for the input guys.
Ron
Old Sep 8, 2008 | 12:15 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Old Sep 8, 2008 | 02:11 PM
camarobird92's Avatar
Car: 95 Z28, 92 Camarobird
Engine: 410 rearwheel hp LT1, TBI 305
Transmission: 4L60E, 700R4
Axle/Gears: 4.11's, Whatever BS GM put in it
Also if you get a 110 mig, use straight CO2 for shielding gas instead of the CO2/Argon mix. The CO2 will cause a little hotter burn, better penetration, and it's cheaper to get filled.
Old Sep 10, 2008 | 11:47 AM
Thanks... good call on the Co2... forgot to mention that earlier.. .
Old Sep 10, 2008 | 09:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the hobart handler is a good unit too
Old Sep 19, 2008 | 05:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The Lincoln MIGs are pretty nice. There was a 110v Lincoln (as well as the usual 220v one too) at the body shop I worked at that worked really nicely, especially on really light stuff like 20ga or 22ga sheet metal... ie. body panels. They have the same ones at school (I'm back in school again) and they work nice there too, lol. I'll probably buy one for myself at some point. Highly recommended, I used one almost every day and I love it. Its nice for a little heavier stuff too, like if you were to put on a set of SFCs or something, its more than capable.
Old Sep 19, 2008 | 08:33 PM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
my brother had a craftsman welder that worked pretty good. for doing body work you dont need the penitration of co2 i would go with the argon co2 mix you get a better shape weld, a little flatter and less penitration. and any lincoln, miller, or hobart welder will be good, but you definatly want to get one that is set up to use shielding gas. my only other recomendation would be to get .023" wire instead of .035" you will be much better off.
Old Sep 20, 2008 | 03:38 PM
Air_Adam's Avatar
Old Sep 20, 2008 | 06:28 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I really like my miller 135.
I second the .024 wire, much better for light work.
Old Sep 20, 2008 | 10:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The brand I have is Cemont (Made in Italy). I bought it from one of the local welding supply stores many years ago so it's old and probably not made any more. I don't know if it's "the best" but on the high setting it was more than enough to put my cage and back half together.
I'd never recommend .035 wire with a 110v welder. It doesn't have the amperage to properly use the heavier wire. .024 works much better. Stay away from shielded wire. It's messy and only good for small projects. Use solid wire and a shielding gas.
My welder has 4 voltage settings. The lowest setting is good for sheet metal work. I only know of two of the duty cycles. At 80 amps the duty cycle is 40%. At 120 amps, it's 18%. Always look for a welder with a high duty cycle.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Kaweh
Aug 9, 2015 02:54 PM
