Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4th gen dash
Old Oct 17, 2008 | 12:58 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
4th gen dash
Ok, so I just now purchased my 4th gen dash out of a 2002 camaro ss. Complete. I already have the 98-02 6 speed center console. 2002, camaro ss, ebony leather seats and matching seatbelts... Oh lord, all this ebony interior... the dash swap is going to happen real soon, as soon as I get it from UPS... Any help would be appreciated...
Old Nov 14, 2008 | 05:50 PM
Daqq's Avatar
Car: 1991 Camaro Z/28
Axle/Gears: 3.73 w/Auburn Posi
Re: 4th gen dash
I'm in the Pensacola Area and would love to see this when finished!
Old Nov 14, 2008 | 05:57 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: 4th gen dash
Buy a '93-96 t/a cluster unless you've converted your car to OBD 2.
The '02 Camaro cluster runs the Tach, Speedo, Odometor/trip, coolant temp & Fuel gauge from Class 2 Serial Data.
If you've got an LS1 then your running OBD 2, or if you've done a 96+ LT1 conversion, otherwise your car doesnt have class 2 serial data.
Good thing, in 1997, GM made the camaro & firebird carry the same shape gauge cluster, which means any 93-02 cluster will physically fit, the 93-96 ones ran on individual sensor wires, which is what you need.
Other then that, good luck with the swap! Im currently putting a 2002 camaro dash into my camaro, ive got an LS1 in mine, so the gauge hookup was easy
Hope all goes well.
Old Nov 15, 2008 | 01:21 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: 4th gen dash
I know all this. My 2002 dash, will fit a 97 lt1 camaro cluster. Its the same dash. So it works out perfectly. Im driving to NJ next weekend to get my t56 and built lt1
Not a problem... Give me a couple months to get this motor put in and the dash all complete, and ill PM you and meet up or something. Another thing Im getting with this motor and tranny swap is the interior harness, so its perfect. Everything = plug n play.
Old Nov 15, 2008 | 03:07 PM
Daqq's Avatar
Re: 4th gen dash
There was a guy in fort walton selling a wrecked 96 trans-am... the side was smashed in and it didn't have an interior, but the engine and transmission were flawless, and with less that 75k miles... I could have had the whole thing for $900, but I had no where to put it...
Old Nov 16, 2008 | 12:18 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: 4th gen dash
Yeah, I got a t56, with spec stage 2 clutch, engine harness, computer, interior harness, clutch pedals, shifter, hydraulics, motor, moroso cold air intake, slp flywheel, all with 83,000 miles for 1,200
Old Nov 16, 2008 | 12:38 AM
Daqq's Avatar
Re: 4th gen dash
I just seen a LS1 + T56 go for $1800 on craigslist in Mobile, AL
Guy said the T56 was rebuilt with warranty, not sure of the condition of the engine, though.
Old Nov 16, 2008 | 11:52 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: 4th gen dash
Yeah but with the ls its not just the motor you need. Its the mounts, maybe the kmem, if you dont modify yours, the wiring is a bitch, the other stuff here and there. And for 1800? I'm pretty sure it had to have ALOT of miles on it
Yes. So I found the add you were talking about, the one he said he paid 3,200 or something for? And he was selling for 1800. I called the guy, he said it was sold. I asked about the mileage and he said it had 160,000 miles.
Old Nov 16, 2008 | 02:41 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Re: 4th gen dash
Any pictures of the install?
Old Nov 16, 2008 | 09:42 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Re: 4th gen dash
I still have to go pick up the setup. Im leaving this friday to get it. I am going to say now, it's going to take me a couple months to complete it. Because I have to work around work and college. I'll keep yall posted
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
