Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
aluminum
Old Nov 8, 2008 | 12:44 PM
85z28nb's Avatar
Car: 85 camaro z28
Engine: 305 but i got a '70 350 LT1
Axle/Gears: 3.08
aluminum
is there any way to weld aluminum? i feel stupid for asking but i dont know much about welding!
Old Nov 8, 2008 | 01:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: aluminum
Yes
Old Nov 8, 2008 | 01:11 PM
Wrenchp's Avatar
Car: 1988 RS Camaro
Engine: Undetermined
Transmission: TH400
Axle/Gears: Stock
Re: aluminum
what you need is a TIG welder with some Al rod.
Old Nov 8, 2008 | 01:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: aluminum
Or a MIG, or a stick, or a torch...
Old Nov 8, 2008 | 09:30 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Re: aluminum
Yeah, the best, cleanest, and most precise will be TIG . Also the most expensive setup though. Later.
Old Nov 10, 2008 | 03:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: aluminum
Do you already own a welding rig of some kind?
If not, do you have 240V in your garage?
What would you like to be able to weld? thickness wise?
Old Nov 10, 2008 | 04:51 PM
Axle/Gears: Stock
Re: aluminum
Or Miller has a couple nice portable unit that plugs into 110v. Later.
Old Nov 28, 2008 | 08:05 PM
Twin_Turbo's Avatar
Re: aluminum
To weld aluminum of any significant thickness and to be able to have proper control over heat (and thus weld pool) you'll need at least a 240 unit and a foot pedal or thumb control. Without it welding aluminum is a PITA. AC is also nice, it can be done with DC if you clean the snot out of the alu and grind off the oxide layer and weld immediately after.
Old Nov 30, 2008 | 06:21 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: aluminum
as you can see from the above replies it can be done . as with anything else practice and more practice . remember the only stupid/dumb question is the one not asked . good luck .
Linson
Oct 24, 2025 02:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
