Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
throttle cable problem
Old Dec 27, 2008 | 05:12 PM
camarodude87's Avatar
Car: 92 rs camaro
Engine: supercharged 355
Transmission: t-5
Axle/Gears: 342
I dont know if Im in the right thread but heres the problem. My cable that runs from my throttle body down the my foot pedal broke today. Im not sure what size cable I need or etc. I kno its a throttle body from a big block, its mounted on a 355, idk if theres a standard size? I called all the autoparts stores around and they dont have anything like that in stock, question is where can I get one? BTW if broke right after the peddal (where it runs into the firewall
thanks
ray
Old Dec 27, 2008 | 05:38 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: throttle cabel problem
Well im more then 99% sure you'll need to order one that came with your car - but what was the organelle motor and fueling system in that car?
Old Jan 1, 2009 | 12:22 AM
Dakine858's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
All you need is a universal throttle cable replacement, they're not available in different sizes. This one will work with your Camaro:
http://www.autopartswarehouse.com/search/?Ne=28&N=6083&Nr=AND(universal:1)&V=9891+1588+4294965653&Vh=1992%20Chevrolet%20Camaro
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
