Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4" custom CAI
Old Jan 6, 2009 | 06:48 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
4" custom CAI
Here is the article I am basing off of my idea http://www.gmhightechperformance.com...ipe/index.html
in fact, the car is almost the same as mine! Its a 396, i am a 385, we have same heads, same cam, they opted for SLP 1 3/4 headers, i have hedman 1 5/8 they had SLP exhaust i have Magnaflow..
Old Jan 6, 2009 | 01:15 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 4" custom CAI
IMHO they screwed things up with the "small" air filter. That 4" air pipe can flow somewhere around 1800cfm. That air filter is no where near that. A 3.5" pipe can flow around 1300cfm and is big enough for 99% of the applications. You just need an airfilter that flows the same or close to it.
Edit: After doing some research that air filter only flows 621cfm at 28". They really screwed up the test.
Old Jan 11, 2009 | 07:48 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: 4" custom CAI
Well I found an air filter thats about 9 inches long and after doing the math it flows around 1200-1300 cfm....so should be plenty....now trying to decide if i should get the Monoblade or stick with the 1000cfm TB
Old Jan 11, 2009 | 09:14 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: 4" custom CAI
My filter is about 9 inches long on my 4 inch intake.
Old Feb 17, 2009 | 03:30 AM
Patrol32's Avatar
Re: 4" custom CAI
What filter p/n# is this one, looks like a good filter. I heard some bad feed back of K&Ns being an expensive way to let garbage into your chamber, not quite so sure if that's true.
Anyways, What do you think of the oval shaped filter that sticks straight on the TB, theorticaly it should flow more due to no tunnel for air pass, it's all straight forward, from the skies and into your plenum. K&N p/n # KNN-RC-5050
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
dusterbd
Sep 29, 2015 08:40 AM
