Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
comp eng sfc's??
Old Feb 18, 2009 | 07:57 PM
  #51
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: comp eng sfc's??
made some more progress on the cage.
threw in a pic of whats hiding under my cheapo ebay valve covers
Attached Thumbnails comp eng sfc's??-img1235007664377.jpg   comp eng sfc's??-img1235008383272.jpg   comp eng sfc's??-img1235008289547.jpg
Old Feb 19, 2009 | 02:05 AM
  #52
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
looks good! uve gotten alot done since this thread has started. keep it up!!
nice harland rockers! those are support girdels right? whats the point of these again? i kno it makes the valvetrain more stable... but is that it? looks like it adds alot of height for ur valve covers and kiss centerbolt covers goodbye
Old Feb 19, 2009 | 08:34 AM
  #53
hey thanks, yea so far ive used two of the smaller rolls of mig wire. now my argon tank is almost empty.
the girdles reduce rocker stud deflection at high rpms. they also lock the valve lash/polly locks in place. you still have to set the lash pretty often, but thats just part of solid roller cam shafts that you gotta deal with. as for center bolt, ah who needs em. lol but i imagine you can drill holes in the girdle if needed.
Old Feb 21, 2009 | 05:55 PM
  #54
Car: 87 TA clone
you kno u can weld with pure C02 right? i saved my argon for my TIG welder and have used 3 bottles of CO2 with solid 70S-6 mig wire. does the same thing but its cheaper.
lol centerbolts are stupid lol even tho i got a set of fabricated aluminum ones with billet rail for 80$!! yeaaaa boyyyyyyyyyy
centerbolts are just easier to get to (the bolts) but i liked the fabbed aluminum perimeter bolt ones too
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
no green
Jan 9, 2016 09:22 PM
