Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Glass mounted third brake light
Old Jan 23, 2009 | 10:53 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Like the ones on the 86's. Has anyone ever omitted it and if so, what did you do to patch the holes?
Old Jan 23, 2009 | 11:06 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: Glass mounted third brake light
after you pull that light, there will be two very small screw holes left....some clear epoxy will do the trick just take your time and apply it for a clean finish and it blends right in with the glass too.
Old Jan 23, 2009 | 11:22 PM
Guro 305's Avatar
Axle/Gears: Stock
Cool! You got a pix?
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
BrianI
Aug 9, 2015 11:52 AM
