Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
3 link whatd'ya think
Old Feb 13, 2009 | 09:06 PM
cprepared125's Avatar
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
heard a lot of autocrossers in my class are switching to a 3 link to get better bite coming out of the corners so i thought i'd give it a try. after months of research and a lot of math this is what i came up with. every piece homemade in the garage
Attached Thumbnails 3 link whatd'ya think-3-link-front-mount.jpg   3 link whatd'ya think-bracket-finished-rear.jpg   3 link whatd'ya think-front-mount-action.jpg
Old Feb 14, 2009 | 02:18 AM
Goosehead's Avatar
Re: 3 link whatd'ya think
i think it looks good!
did you use some kind of special welding technic for welding the cast iron rearaxle?
Old Feb 14, 2009 | 03:58 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I like the choice to offset the upper link. That should help it stay nice and even on exits when you apply the power in the lower gears.
I would keep an eye on the welds around the axle bracket though. That upper link see's a lot of force. Keep an eye on it, and if you see any signs at all of deformation, or cracking you are going to want to add some additional support.
BTW, who do you auto-x with down in springfield?
Old Feb 14, 2009 | 11:56 AM
Transmission: t5
i autocross with eescc in eugene/springfield and with acco in bend/redmond. non of the other cp-ers in my club have the 3 link but it seems a lot of nationally competative cars run them
Old Feb 14, 2009 | 12:35 PM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
looks bad as$!
Old Feb 14, 2009 | 02:38 PM
Transmission: t5
the only thing that makes me nervous is that i used 5/8 rod ends with only a 12,000 lb. rating. i almost think i'll need to replace them with heavier duty ones before competition
Old Feb 14, 2009 | 03:03 PM
rayar's Avatar
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
Looks good. Lots of adjustment. Just wondering how long the upper link is.Going with a torque absorber style bar might be a good idea but if that bar is as short as I think it is you won't have enough room to fit one.
Old Feb 15, 2009 | 12:28 PM
Transmission: t5
upper link is 15" hole to hole. i wanted to go with a torque absorber style but at the time i was unemployed and racing season is coming up fast so i just decided to go the cheapest and fastest route. i still have a ton of work to get this car ready to race
Old Feb 15, 2009 | 12:53 PM
rayar's Avatar
Car: 83 Camaro
Transmission: TH350
It is the same length as mine then. I just must have everything farther forward because my front mount is allmost even with the main hoop on the cage.
I did build a bracket off of my torque arm mount for the upper link on the axle but it go's back to the top of the housing so I am not sure where the difference is.
I understand about being unemployed. That where I am right now, Laid off right before Christmas and not a decent paying job around. The good thing about it is I am getting my own very small business going. Another month or 2 I should be making ends meet again and by mid Summer I should be very busy. The best part is never needing to worry about being laid off again. I hope I never need to work for anyone again.
Old Feb 15, 2009 | 02:53 PM
Transmission: t5
ya i'm back to work now but now i have the money and no time to work on it.
My front hoop is a couple inches further forward than most i've seen. My rear mount is about an inch behind of the centerline of the axle so that may be why it looks so different
Old Feb 17, 2009 | 09:28 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Looks good. That doesn't look like the stock 7.5" ten bolt. Is that a Dana?
You should check out www.frrax.com. You'd fit in good over there.
Old Feb 18, 2009 | 07:55 PM
Transmission: t5
yup it's a dana. got it off some guy who thought it was a stock disc brake 10 bolt. $200.00 not a bad deal huh
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
