Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Automatic Belt Tensioner Redesign
Old Mar 8, 2009 | 10:53 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
For the last two years, I have ran without an ac compressor/delete pulley and smog pump pulley, by using a grooved tensioner pulley. Well, I am changing the air intake and need to mount the tensioner lower. So I have decided to put a new bracket with tensioner in. I am trying to modify something that was factory but not as bulky as the factory one.
Right now, I am shooting for something that uses two of the front bolts in the head and retains the stock alternator, power steering, crank, and water pump setup. I have measured the depth to the inside of the pulley to 6 inches, but can someone give me a more precise dimension.
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
bjpotter
Oct 4, 2015 07:48 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
