Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
A-Pillar bars/thru dash bars
Old Mar 17, 2009 | 01:13 AM
jake_91_rs's Avatar
Car: 1991 RS Camaro
Transmission: 5sp
who makes a roll cage kit that goes thru the dash instead in front of it. I cant seem to find any pics anywhere of a "pre bent" kit that goes thru the dash. any help is appreciated
Old Mar 17, 2009 | 07:25 AM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Re: A-Pillar bars/thru dash bars
i got my thru dash bars from s&w. I called steve spohn and he gave me a number of a guy at s&w and he hooked me up. i just got my front bars fitted and tacked in...weather hasn't been too great to finish weld the cage. The two front down tubes are by far the hardest two tubes on the whole cage to fit...it's a complex notch. i wound up with a large gap and i had to reconstruct the tube slightly (i didn't see anything in the nhra rule book about this being illegal...it checked out with a dye test and you'd be hard pressed to tell otherwise). just make sure to leave yourself room to weld the top of the notch...mine is tight and i'm going to have to wait til i can get my car in the garage and get the windshield out to weld all the way around it.
Old Mar 18, 2009 | 08:01 PM
Bruce91RS's Avatar
talk to Keith at Vanishing Point Race Cars.215 721 9165.They can make you a kit anyway you want it.
Old Mar 20, 2009 | 03:19 PM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Build it youself! Heres mine, started life as a pile of straight tubing.
Old Mar 20, 2009 | 04:43 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
jegs.com
MantyZ28
Nov 8, 2015 06:54 PM
aharvel50
Sep 21, 2015 07:31 PM
codeysabatini
Sep 20, 2015 11:36 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
87camaro87
Sep 9, 2015 10:29 PM
