Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Formula hood vent
Old Mar 7, 2009 | 12:47 PM
bgmoss's Avatar
Car: 1986 TA t-tops
Formula hood vent
Hi,
I notice that when I take off the block-off plate on my 89 formula 350 tpi, alot of heat escapes out near the back. I think this is a good thing, helps cool the plenum and runners- helps preserve the paint on the hood - etc. I'm just careful not to shoot water in there when washing it.
Does anyone make a louvered or mesh-type replacement for that block-off plate?
I don't want to try to modify mine, but keep it in case I want it stock again in the future.
I figure I could buy some mesh material and cut one out with some tin-snips, but first wanted to explore this board for other ideas.
regards,
-Brent
Old Mar 21, 2009 | 09:24 AM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
Re: Formula hood vent
I know of the 82/83 style hoods that were functional they came with mesh screens. If you can find one of those hoods you could scavange one from there. If not, I'd try eBay or make your own. HTH
Old Mar 21, 2009 | 11:29 AM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
It makes a big difference letting heat out, if you have that rubber hood seal on the rear of your hood, it doesn't let water in but also doesn't heat out. I noticed a difference. I purchased mine off ebay years ago.
Eric
Old Mar 21, 2009 | 12:47 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
My '84 Trans Am uses engine vacuum to close the flap anytime the engine is not at full throttle. Not helpful. So, the '70 Chevelle SS 454 LS6 had a setup to control it's hood flap electrically, there was a thing on the carb for the kickdown of the TH400, but it got installed even with the Muncies.
Anyway, any of the restoration parts companies that have stuff for this car might be able to help you modify an '82-'84 hood to be electric instead of vacuum. Then you set it up to be closed except when energized by a switch in the car. Add a switch wherever you like, run the wiring. It'll be closed whenever you're away from the car, and you can close it the second it starts raining.
Hotrodboba400
Dec 10, 2019 07:07 PM
90formulaVortec
Sep 8, 2015 12:42 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
