Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Partial Floor Patch Panels????
Old Apr 21, 2009 | 01:21 PM
mikeiaz's Avatar
Anyone know of a source for partial floor patch panels for 3rd Gens?? I don't need or want the full floor panels but that is all I have seen for sale.
Old Apr 24, 2009 | 11:18 AM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: Partial Floor Patch Panels????
cookie sheets.
Old Apr 24, 2009 | 11:21 AM
Firebat's Avatar
Just pick up some sheet metal from about any hardware store. Try to go slightly thicker sheet metal than what you had before.
Old Apr 24, 2009 | 05:50 PM
1990z28's Avatar
Car: 1990 Z28 Camaro
Try classicindustries.com I think I might of seen them in there catalog.
Old Apr 25, 2009 | 11:54 AM
mikeiaz's Avatar
Nothing at Classic industries, already checked.
I know I can use sheet metal stock but was hoping to find actual formed parts that would be exact.
Cookie sheets? When the floor gets warm do you enjoy the smell of home baked????
Old Apr 25, 2009 | 07:40 PM
88iroc52387's Avatar
http://www.ecklerscamaro.com/product...0&dept_id=2206
Best bet if you want some random quarter of a floor pan your going to have to find a local place that fabricates panels. I have a place here by me in ohio that will fabricate small parts for you if you cut a section a bit bigger then what you want to patch and give them a rough idea of what the piece should look like. Anything smaller then a full floor pan you mine as well bring out the old cookie sheets.
Old Apr 26, 2009 | 11:08 AM
mikeiaz's Avatar
OK just to be clear, I hav alrady checked Eckler's, MidAmerica, Classic Industries, etc -those are all FULL floor pans.
I was hoping someone was making partials that would contour to the existing pans, the holes in mine are small - one the size of a dime, the second about 1/2" by 3" (yes they will get beigger when cut out), so looks like I will go with sheet metal stock. Can't believe no makes partials, oh well.
wigmobile
Feb 26, 2025 02:56 PM
BWilcox
Sep 20, 2015 12:19 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stryker412
Sep 7, 2015 09:11 AM
mrdevontay
Sep 2, 2015 08:04 PM
