Torque arm mount question...
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
I am fabricating a crossmember for a tko 600 and was wondering if I need the bushing for the T-arm or if I should just bolt it to a bracket.
Is that mount just to dampen vibrations or more?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Torque arm mount question...
the torque arm need to be able to move front and back slightly. It cannot be mounted rigidly or it will break things.
The bushing is for vibration and noise reduction, its not a bad idea to keep some kind of bushing.
Engine: 383
yea thats true, it does move some with the rear end...
maybe I will weld a tab on to the stock mount to the crossmember.
morrow
Jan 13, 2024 12:29 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
