Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Selling EGR block off plates (aluminun) need dimensions
Old Jun 2, 2009 | 09:25 PM
2LTCamaro's Avatar
I am getting ready to fabricate and sell aluminum EGR block off plates. I need the dimensions for all engines. If you are the first to post for an engine model with the correct dimensions you will get a plate free. Thanks for the help in advance.
Old Jun 7, 2009 | 01:12 PM
2LTCamaro's Avatar
Re: Selling EGR block off plates (aluminun) need dimensions
Bump stilll need these!
Old Jun 7, 2009 | 06:17 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
1984 z28
A=2 1/4"
B=2 3/8"
C=3 1/8"
D=2 1/8"
its a bit of an odd shape to get good measurements but i hope this helps a little
Attached Thumbnails Selling EGR block off plates (aluminun) need dimensions-sspx0433.jpg
Old Jun 7, 2009 | 06:22 PM
2LTCamaro's Avatar
Originally Posted by Brennan
1984 z28
A=2 1/4"
B=2 3/8"
C=3 1/8"
D=2 1/8"
Cool thx. That's the 350 right? So that should work for all 350 and 305s. Want a free one?
Old Jun 7, 2009 | 06:32 PM
2LTCamaro's Avatar
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Brennan's Avatar
the manifold is from a 305 and the 350 wasn't available in 84. im using the manifold on my 350 though. and sure a free one would be nice, but i am in Canada if thats a problem. if not ill pm you my address.
Old Jun 7, 2009 | 10:03 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
How much are you going to sell them for? That pic looks nothing like a TPI egr block off plate. (100-021 for TPI camaro/firebirds)
Old Jun 8, 2009 | 03:33 PM
Brennan's Avatar
mines carbed
Old Jun 8, 2009 | 06:07 PM
2LTCamaro's Avatar
Ok so I have the carbed specs, i still need the specs for the TPI and TBI. Probably gonna sell them for $20 shipped.
Old Jun 8, 2009 | 06:45 PM
AmorgetRS's Avatar
If you don't have it for TPI, I'll grab you the dimensions tonight.
Old Jun 8, 2009 | 06:48 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
i want a tpi egr block plate!
Old Jun 13, 2009 | 12:17 AM
bitchin86's Avatar
Car: 1986 iroc-z
Engine: lt1 intake 406
Axle/Gears: stock 89 gta 10 bolt 3.42 non posi
the one for tpi is
3 1/16 inch hole to hole, 3 3/4 long over all, and 1 4/16 wide.
this is off an 86 tpi 305
Old Jun 13, 2009 | 12:34 AM
bitchin86's Avatar
Car: 1986 iroc-z
sorry for the crapy pic this is the corect size the first width was wrong the one on the pic is corect.
Attached Thumbnails Selling EGR block off plates (aluminun) need dimensions-egr-blockoff-plate1.jpg
Old Jun 14, 2009 | 08:34 PM
2LTCamaro's Avatar
cool thx bitchin I still need the TBI if anyone can get it. I can't start making and selling these until I get all the specs for all of them. I have someone standing by to get these going.
Old Jun 15, 2009 | 11:23 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Are you serious? You plan to build and sell products for which you got dimensions from strangers on a message board?!?! No precision or tolerances needed, just eyeballed with whatever ruler was lying around for all you know. You don't even know what size bolts are used for each application to know what size hole has to be drilled (because those dimensions aren't provided either). Only one of the pictures posted gives a dimension for the distance between the centers of the bolt holes. If you can't get ahold of copies of GM drawings, you could at least get actual parts in your hands to take accurate first-hand dimensions.
Old Jun 17, 2009 | 02:55 PM
imjustsean's Avatar
Car: 91 rs
Engine: 305 tbi
why dont you just cruize on down to autozone and spend a dollar on the egr gasket? thats what i did for my tbi now i gotta figure out how to ritchen my a/f mix back up cause i'm runnin lean.
Old Jun 22, 2009 | 12:15 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Tool.
Old Jul 6, 2023 | 09:25 PM
danielraspberry's Avatar
I have an old egr and intact gasket if you want to give me your address so you can use them for a template came off my 1989 gmc Sierra SLE k1500 350ci 5.7L tbi
Old Jul 6, 2023 | 11:52 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
14 years later??...
Old Jul 11, 2023 | 01:39 PM
big::tone's Avatar
Originally Posted by T.L.
14 years later??...
Yeah... Damn. I got excited by the current dated post because I need one...
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
1985chevydude
Aug 20, 2015 12:29 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
