Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Retapping a hole
Old Sep 18, 2009 | 11:59 PM
paveuk's Avatar
Retapping a hole
I have a 1.25"ID titanium tube with 24 threads per inch but I want 12 threads per inch. Can I just run a 12tpi tap down there and get the new thread count?
Old Sep 19, 2009 | 02:20 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Retapping a hole
Wouldn't recommend it without going to a bigger size. Ordinarily I'd say the metal will be brittle and barely hanging on, but titanium is quite tough and soft... might turn out alright. If you can switch between SAE and Metric you might be able to get the equivalent of a quarter to half a size larger instead of a full size.
Old Sep 19, 2009 | 03:48 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I would not do it. I am a machinist though so it may work but I know from the professional standpoint, that's not a good idea.
Old Sep 19, 2009 | 10:28 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Don't do it. Either suck it up and use the 24tpi or buy another one that is coarse thread.
Old Sep 20, 2009 | 10:57 AM
paveuk's Avatar
thanks guys well I have to cut the length down anyways too long, so the threads will be gone now. but now I might use a tube adapter in the end but can't weld titanium to chromoly. You know anything you machinists use that I can basically "glue it in? like jb weld. Or like a solder or braze? I'm also gonna drill a hole and put a bolt thr the rod and tube adapter since I can't weld it.
Old Sep 20, 2009 | 12:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the fine threads, 24TPI and much shallower than the 12tpi. You need to get to correct drill bit for the 12tpi tap, drill the threads out, and re-tap. It may work just fine, but measure first. However, if the 24TPI the same bolt size as the 12? What thread and diameter sizes are you looking to use.
if you just jam the new tap in there you will most likely end up with a broken tap or useless threads.
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
drumstixer
Sep 29, 2015 03:02 PM
