Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Home Made Ramps
Old Sep 22, 2009 | 10:24 PM
MitcherNeaf's Avatar
Home Made Ramps
Hey guys was thinking about making a set of these, I really like the design of the one on the bottom of this page
http://www.corvettec3.ca/ramps.htm
he uses 2 2x6's instead of 1 2x12 to save on money, but it doesn't say anywhere what he uses to hold the 6's together securely. to me it looks like essentially the ply wood or osb wood is holding it together. Would you use 2x12's for the supports running vertically and use the 2x6's for the platform?
thanks
Mitch
Old Sep 22, 2009 | 10:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Home Made Ramps
I'd use 2x12's for the supports. The 2x6's for the platform would be fine with some 3/8" plywood on top. The OSB is fine for the sides as it's not really load supporting. Since the car's wheelbase would put it in the same location every time, I'd add more support or even metal support under where the wheels would stop.
The one at the bottom with the built in lights and storage space is a good design.
Old Sep 22, 2009 | 10:50 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: Home Made Ramps
Wow! That is definitley different. The first few pics looked kinda scary but seeing the inside it seems to be pretty well built. Seems like a cheaper alternative to a four post lift.
Old Sep 22, 2009 | 10:57 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Home Made Ramps
there is an old post around here somewhere about the full drive up on homemade ramps
do a search, you may find it pretty fast
Old Sep 22, 2009 | 11:16 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Home Made Ramps
yea theres already a thread on this. . .
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Amillionoh7
Sep 11, 2015 11:36 AM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
