Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Aluminum fuel line?
Old Oct 4, 2009 | 09:42 PM
cautrell05's Avatar
Aluminum fuel line?
Trying to plumb a Ramjet into my 68 and was wondering if 3/8 aluminum line was acceptable for efi hard line. I have 3/8 steel but my an flaring tool wont touch it. Thanks
Nick
Old Oct 4, 2009 | 10:06 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Aluminum fuel line?
I used 1/2" aluminum line on my past setup that had 90psi at max, not a problem here.
Old Oct 5, 2009 | 06:27 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
You will just have to watch out if you are connecting steel and aluminum together as you will suffer corrosion since they are dissimilar metals.
Old Oct 5, 2009 | 08:44 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
If it's a street car, steel won't get damaged as easy by loose stones or whatever you may encounter when driving.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
