Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
aluminum trim pannels
Old Jul 22, 2009 | 12:39 PM
bajorf's Avatar
i used made some trim pannels and used the heater control bezel and epoxy'd the cut up peace to the aluminum i should have taken more pics but i really wasnt thinking about posting it up
Old Jul 22, 2009 | 01:54 PM
Warrior's Avatar
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
Re: aluminum trim pannels
Cool
Old Jul 22, 2009 | 03:03 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
very modern. are you going to do anything with the trim or leave it like it is? you can take it out and crinkle coat it so it looks like an aircraft switch and gage panel - with those you can do anything.
how did you do it and how much time did it take?
Old Jul 22, 2009 | 03:49 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Maybe put some cupholders where the ashtray used to be?
Old Jul 23, 2009 | 10:40 AM
bajorf's Avatar
i am gonna polish it more and put my nitrous switches where the ashtray was
I had some old street sign from my last job
1 took the old panels off cut the ashtray from shift plate
2 traced all the parts and cut the with a saber saw then took a small angle grinder w 60 grit disc and ground till i got the the scribe lines
3 took heater control plate and cut the filler out and sanded it till it was short enough to go between the plate and heater controls
4 made some 90 degree peaces of sheetmetal and epoxyd them on the back then epoxyd the plastic peace onto the plate
Old Jul 23, 2009 | 10:45 AM
bajorf's Avatar
Old Oct 5, 2009 | 10:10 PM
kzhurley's Avatar
Car: 86 IROC-Z
Engine: 406
Transmission: TH400
Axle/Gears: Ferd 9 inch/ 4.11 spool
I dont know how much you plan on polishing it but when i first made mine I used #8 polish alum and it was so shiny that it blinded me some times when i drove..Then i pulled them off and powdercoated them light gray..Just something to think about...very nice job though.....
Old Oct 5, 2009 | 10:28 PM
kzhurley, are those Z-series gauges? Reminds me a lot of what I did with mine, except that I only mounted an oil pressure and water temp into the stock trim plate, with a "backing plate" kinda deal (I wanted it to blend in, mine looks like it belongs in my opinion). Looks good, but what's the switch for if i may ask?
Old Oct 5, 2009 | 10:42 PM
kzhurley's Avatar
Car: 86 IROC-Z
Engine: 406
Transmission: TH400
They are z series i believ..closest thing i could find to match the factory lettering that i coul afford..oil.water temp,and trans temp..I put the switch there as kind of a security thing..when you shut it off you can remove the key part and not many would look twice..And also if i have to turn off the fire for some reason in a hurry i dont have to worry about the column locking up on me..I plan on maybe pulling the parts back off and powdercoating them black wrinkle but im not 100% sure yet cause im working on something for my door panels yet..I'll stop thread jackin now...
Old Oct 5, 2009 | 11:27 PM
I like the gauges, like you said they match the rest of the car well. So it's kind of like a kill switch? And I need to do something with my door panels as well... Can I ask what your idea is? Thread jacking, Muahaha
Old Oct 5, 2009 | 11:52 PM
kzhurley's Avatar
Car: 86 IROC-Z
Engine: 406
Transmission: TH400
Aluminum and full access to cnc machines at work..Thats all i need to say right now..I'll start my own thread on that one when i see how it'll turn out...Plans are alredy drawn up and programmed just waiting on material to come in for it..Yep pretty much a kill switch..
Old Oct 6, 2009 | 12:00 AM
Sounds shiny
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
