Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Thinking of doing a 4 link and 9 inch rear
Old Jan 13, 2010 | 08:20 PM
Eric89sc's Avatar
Car: 1989 camaro
Engine: 357 procharged
Transmission: turbo 400 with Transbrake
Axle/Gears: 342 posi
Ive been trying to see if any one has a bolt in 4 link set to put in a third gen camaro. the only thing I could find is this http://www.camaros.net/forums/showthread.php?t=139976
its for a 1 gen camaro but I think something would work alone this line for a third gen. any thoughts???
Eric
Old Jan 13, 2010 | 08:48 PM
bitchin86's Avatar
Car: 1986 iroc-z
Engine: lt1 intake 406
Axle/Gears: stock 89 gta 10 bolt 3.42 non posi
Re: Thinking of doing a 4 link and 9 inch rear
there isnt enough room under a thirdgen for a bolt in 4 link.
you have to cut out most of the rear floor pan and back half the car
Old Jan 15, 2010 | 02:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what he said
Old Jan 15, 2010 | 06:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
https://www.thirdgen.org/forums/fabr...k+half+project
You could do an unequal length, triangulated 4-link system just to be different but it isn't a good performance setup. Some SuperStock cars have an unequal length 4-link because they're not allowed to modify the floor or don't have the room to do it but it's not a triangulated system.
The axle of a third gen sits very high up in the body. There isn't a whole lot of room to do many changes.
Old Jan 16, 2010 | 04:26 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
You may want to check into a "mini" 4 link. They talk about it on ls1tech. They get hime joints and weld tabs to control arms and axle tubes..connect them and have a lil adjustment. I would just be worried about pinion angle change upon spring compression
Old Jan 16, 2010 | 06:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats more like a ladder bar, and very similar to lakewoods traction/lift bar setup. Not the best thing going considering the potential of the torque arm setup
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
midge54
Jan 29, 2017 07:00 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
