Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
IDEA for someone to hopefully produce...
Old Jan 28, 2010 | 01:35 PM
C Murda's Avatar
Car: 91 Z
Engine: Somethin Nice!!
racecraft makes these tubular front bumper supports for 4th gens and they are an EXCELLENT piece and they replace your factory inner support and they fully brace the front bumper cover from caving in at high speeds due to the wind force... it would be AWESOME and im sure a great seller if someone can mimick the Racecraft piece but have it designed to support the 3rd gen front bumper cover. it would allow for room for big intercoolers and shed a few lbs and it would solve the issue of the front bumper deforming at higher speeds. piece would need an upper tube and lower tube to support the main squared section of the bumper and then the lower portion where our front chin spoilers are attached.
if someone can make a good piece that does the job ill surely be the first to buy one
Old Jan 28, 2010 | 01:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: IDEA for someone to hopefully produce...
Why don't you just tell Racecraft to produce the same thing for a third gen?
Old Jan 28, 2010 | 10:33 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Yep, they'll do it if enough people want it.
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
