Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Where could I find a belt to fit?
Old Feb 7, 2010 | 10:21 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Im thinking of removing my A/c and P/s, using the G20 a/c delete box and a S10 Manual p/s box. Where could I find the right size belt to fit the alternator, water pump, crank, the idler pulley under the alternator and tensioner? Also how would I route it?
Im thinking it would really clean up the engine bay alot. Also it's a 88 V6 Firebird, with a worked 3.4L
Old Feb 8, 2010 | 02:00 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: Where could I find a belt to fit?
bump
Old Feb 8, 2010 | 02:21 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
take a string and route it where the belt would go, cut to length and take it to your parts store and they will find a belt that matches.
Old Feb 8, 2010 | 07:56 PM
Pocket's Avatar
Car: 91 Trans Am
The string method works, I had to do it for my twin car
http://www.goodyearep.com/productsdetail.aspx?id=3128
Here are a list of PNs with lengths. After reading a few you should start to see the pn-length pattern which applies to most every belt mfr
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
mcquigg
Aug 13, 2015 02:26 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
