Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Lambo door fab... ?? help
Old Feb 4, 2010 | 02:56 PM
augie1209's Avatar
Hey guys gotta question about AUTOMATIC lambo doors. I got the hinges already, but was wondering if i need a certain type of actuator, like length wise. Also, when i install shaved door kit, will i just hook this up to actuator like with the automatic remote, or do i need to get another remote for actuator, i wouldn't think i would but im not sure. Just trying to get the right size actuator and the right stuff. Also, with the shaved door kits, does is matter the lbs of the solenoid ive seen um from 15 to 50, just wondering, i can get a great deal on new kit that has 15lb solenoid, but just wonderin if this will work for my camaro!! let me know and if you could address each question i would appreciate it thanks..
Old Feb 4, 2010 | 03:47 PM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Re: Lambo door fab... ?? help
never seen lambo doors on a 3rd gen >.>
once u get this all figured out and done post some pics >.>
Old Feb 7, 2010 | 12:02 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
I was thinkin about doin this at one point but decided against it because of the weight of the doors. Ik autolock makes a fully automatic universal kit, may want to see what all that has to figure out what youll need if you don know already. Also may want to check out see if there is some forums about lambo doors and if all else fails you might have to look on a r!cer forum. Idk if anyone else has done lambo doors on here but the people on those other forums may be quite a bit of help
Old Feb 7, 2010 | 10:22 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Fully dressed, power everything, third gen doors are 105 pounds each. It takes very little effort to pull the release lever. If in doubt, use a fish scale to see how much effort is required.
Old Feb 7, 2010 | 12:01 PM
augie1209's Avatar
Alright guys thanks alot.. also.. if i use the automatic setup with actuators..will i still need gas struts or do the actuators take place of this?? and how many channels on a remote wil i need.. i plan on hooking up both actuators and both door poppers?
Old Feb 7, 2010 | 12:27 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Not very familier with the lambo door stuff but i'm pretty sure you would still need the struts in the hinges to help with the weight of the door. Just like a garage door still needs helper spring with an opener.
As far as how many channels that all depends on how you want it to work but I would guess 4. one to unlatch each door and one to auto open each door individually. I assume you can get rid of the power lock actuator because there wouldn't be much use for them anymore. however if you have an alarm you would need a channel for to arm and disarm and I always liked to have a trunk relase. so that would put you at 6 and if you want remote start 7.
Old Feb 7, 2010 | 10:30 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
all I have to say...
Old Feb 8, 2010 | 06:12 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I nabbed a pic off of this site awhile back just in case I ever decided to go this route. Not sure who the owner is, but I'm sure he'll chime in sooner or later. Anyways, here you go....;
Old Feb 8, 2010 | 07:09 AM
AlkyIROC's Avatar
Car: 87 IROC L98
That looks so ugly
Old Feb 8, 2010 | 09:15 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I shaved the door handles on my Camaro when I first got it. I think I used 35lb solenoids and they are plenty. I found a rebadged Autoloc kit on Ebay for cheap. Actually, they are bit too much. They REALLY make a "THUNK" when they open the doors. You could probably get away with 15lb or 20lb solenoids.
As for channels, it depends on how many functions you want to control and how you want to control the doors. Obviously you need to do each door separately so that's 2 channels right there. If you want the doors to open and swing up in one motion then you can probably get away with one channel. You could do it with 2 button presses if you want, but that would add 2 more channels.
What you need to find out is how far out the doors swing when you pop them with the shaved kit. My doors don't pop out far enough to swing up on lambo hinges if I had them. I don't have any spring-loaded pushers though and if you add those it may swing the door out far enough for the lambo hinge to work.
So you're most likely at 4 channels there. A trunk release is real nice so thats 5 channels. If you have an alarm thats more channels. FWIW, my shaved remote has 8 channels and I'm currently only using 3 channels - 1 for each door and 1 for the trunk. I'll be using another soon to roll my windows down automatically so I don't have to open the doors to take my T-tops off.
Old Feb 8, 2010 | 10:42 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
my alarm has 7 channels, i'm doing suicide doors, shaved handles. once you shave the handles there's no use for door locks so you can use the door lock circuit for some things too but it's a switched polarity circuit... so not too useful.
i'm using 3 channels: trunk, door pop 1, door pop 2. then if you count remote start as a channel there's another, and then i still arm and disarm. plenty of room to expand
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
