Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Racing seat install how to ?
Old Feb 19, 2010 | 08:13 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I have some racing seats that I want to put in my camaro this year only thing is I have never done it. #1 they are for a 5 pt harness, is there a good way of being able to use that harness or maybe even a 3 pt with out a cage to attach it to ? # 2 I'm thinking its do able but i figure i might as well ask can I re use the track from my old seats and mount the racing seats to it ?
Old Feb 19, 2010 | 11:29 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: Racing seat install how to ?
YES YES YES.
You can do all those things.
Very easy with a little welding. But if you can't do that, you can bolt it all togeather.
Go to my car's site on cardomain.
I have a tech article I wrote a few years back about how to do all of what you are saying.
Post back with questions.
Old Feb 19, 2010 | 11:47 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
No way to run a 5 point harness safely without at least a 4 point roll bar with welded cross bar located near your shoulders.
Old Feb 19, 2010 | 12:17 PM
Engine: LS3
Thats not true. You can run 6" x6" plates above and bellow the attachment point. The points have to be in the right locations. Between the rear seat cussion and the rear backrest, bolted down with plates is fine. The other 3 can go thought the floor. I did the propper re-search when I was doing mine. As long as the rear belts are at an angle that is greater than 15° from the back of the seat they are valid. I would not run an angle that sharp, but that is what was listed with my belts.
You don't need a cage, although it is safer and easier, assuming your cage is installed by a competent shop.
Old Feb 19, 2010 | 09:22 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Racing seats----are they the cheapo plastic ones, steel frames, or aluminum???? I would hesitate to install one of the plastic seats if there is no crossbar to attach the back of the seat to....
Old Feb 22, 2010 | 12:42 PM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
The correct way to use a 5 point harness is to run the two shoulder belts to the cross bar of a roll bar / cage. To pass a tech inspection, the back of the seat must be supported (typically by a brace running to the cross bar of the main hoop of the roll bar / cage). If you are thinking about using sheet aluminum seats (Kirkey, Jaz, etc), then Racecraft Inc makes bolt in and weld in seat brackets. One word of caution, for whatever reason the passenger side brackets didn't exactly fit the floor of my car (82 camaro). They're listed for third and fourth gen's, but I think the passenger side floors are different; it required a bit of modification to fit, but all in all they work very well.
I personally would not recommend running the shoulder belts back toward the rear seat area. Most harness manufacturers recommend they go to the cross bar of a cage, which is only supposed to be a maximum of 4 inches below your shoulders. I'm sure running them to the back seat is considered too steep of an angle, and besides that it probably doesn't look that good.
Old Feb 24, 2010 | 07:12 AM
Engine: LS3
I run mine there. It is not too steep. I have measured it. Also when I am not using them, I pull them out of my seat, role them up and they can tuck behind the cushions. You can't see them at all and I can still recline.
IN MY EYES: Best of both worlds. And it is tech/track legal to run 4" x 4" plates above and bellow the attachment point in a unibody car.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
z28addict8490
Aug 7, 2015 08:48 PM
