Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
S10 HEATER BOX?
Old Nov 10, 2009 | 07:37 PM
mesosneaky's Avatar
S10 HEATER BOX?
http://cgi.ebay.com/ebaymotors/1982-1993-Chevy-S10-V8-Heater-Box-w-Motor A-C-Delete_W0QQcmdZViewItemQQhashZitem4cebe45ce5QQitemZ330375126245QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
WAS WONDERING IF THIS WOULD FIT MY 84 CAMARO?
SORRY ABOUT CAPS MY COMPUTER IS STUCK LIKE THIS BECAUSE OF A GAME IM PLAYING.
THANKS FOR RESPONSE
Old Nov 10, 2009 | 08:12 PM
camaro391z's Avatar
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
Axle/Gears: 10bolt/4:10
Re: S10 HEATER BOX?
mite be able to fab one on there from an old body style one..... def wouldnt be a direct fit. i know the new body style is kinda weird lookin
Old Nov 10, 2009 | 08:22 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: S10 HEATER BOX?
you may be able to make it work, but it would not be a direct bolt on.
the newer model s10 ones are just a bit different, and they are plastic/fiberglass as well, so it wont rust.
they used to be available at the dealer for cheap. im sure its discontinued now, but it might be worth the check.
the dealer can print an exploded view so you can at least see what shape it is and go from there....
good luck.
Old Nov 10, 2009 | 09:11 PM
mesosneaky's Avatar
Re: S10 HEATER BOX?
so that ebay one may fit pretty good with little modification?
looks like its really close. figure it would be better paying half price for a s10 instead of 100 for a camaro one.
Old Nov 10, 2009 | 09:34 PM
mesosneaky's Avatar
Re: S10 HEATER BOX?
well I bought it ill let you know what i have to do to MAKE it fit.
Old Nov 11, 2009 | 10:33 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: S10 HEATER BOX?
im confident you can make it work, but how much labor and fab work are you going to have to do?
my time is money. the factory fit would be a no brainer, but saving a buck is always good.
good luck.
post up your results.
Old Feb 24, 2010 | 07:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: S10 HEATER BOX?
Did you get the s10 box to fit?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
