Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fuel cell in front of rad
Old Feb 21, 2010 | 07:08 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i want to put a 5gal fuel cell in front of my rad support. has anyone ever done this. if so can you post some pics of it so that i can get an idea of what im in for. thanks alot
Old Feb 21, 2010 | 09:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: fuel cell in front of rad
I don't use a full size rad. I use a tiny rad from a Pontiac Firefly since my alcohol engine doesn't produce a lot of heat. My fuel cell is mounted beside the rad. My rad support has been cut out and a simple brace replaces it just to mount stuff.
How you mount it depends on the size and style. It's possible to mount a fuel cell on the driver's side behind the headlights/rad support.
Old Feb 22, 2010 | 11:36 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
I mounted mine in the right forward battery box area. Here's the link with the pics...
https://www.thirdgen.org/forums/post...35-post21.html
Old Feb 22, 2010 | 12:15 PM
83 Crossfire TA's Avatar
Ever have any problems with that at the track? It used to be at a lot of races any modifications to the core support either automatically disqualified you or at least moved you up a class... haven't looked lately if that is still the case (had a friend with an almost stock mustang, with a junk motor and twin turbos that cut part of the core support for the charge pipe from the intercooler and it seemed like that ruined more fun than anything else, but it's been a few years and similar setups have gotten a lot more common.
Old Feb 22, 2010 | 06:24 PM
Car: 84 camaro Z28
Engine: 434sbc
Tony V did you make some sort of a box to go around the bottom of that. also was size is that cell?
Old Feb 22, 2010 | 07:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Nothing in the rulebook says I can't change my car whichever way I want. I don't fall into those restrictive "classes". As a bracket racer, I can do just about anything I want to my car. There's a tubular brace going under the rad to add some support to the frame rails but even that's not really required.
Old Feb 23, 2010 | 07:29 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
I put some sheetmetal on the forward side of the wheelwell to keep debris kicked up by the front tire from hitting the cell. It's a 4 gal tank.
Old Feb 23, 2010 | 06:42 PM
Car: 84 camaro Z28
Engine: 434sbc
i too will be running alky with my new setup. this is my first time with alcohol. i worried that a 4 gal cell wont be enough for the motor. its a pretty healthy small block (about 720-730hp). i have a sumped tank but ill be using a belt driven fuel pump. i think it would be better to have a cell up front than use the one in the rear.
Old Feb 23, 2010 | 10:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
If you mount one in the rear, you should use an electric pump to push it up to a front surge tank. Some people have had no problems using a belt driven pump with a cell in the rear.
My fuel cell holds 4 gallons. I fill it up after every pass. I can make 2 full passes if I have to skip a refuel and do a hot lap. Typically I use up 5 gallons of fuel to make 3 passes down the track. That's 1/4 mile at WOT then all the way down to the end of the track and back to the pits. Total distance traveled is 2 miles (it's a road course route to return to the pits from the very end of the track). If I got towed through the staging lanes and back up the return road, I wouldn't use as much fuel. My sponsor buys me alcohol so I don't worry about how much I burn.
When I go to the track, the fuel cell is full and I have 3 full jugs. Warm up usually uses 1-2 gallons of fuel. Technically, I have enough fuel for 9 good full passes plus some warm up time or excess idling in the staging lanes trying to build heat in the engine.
Old Feb 24, 2010 | 06:50 PM
Car: 84 camaro Z28
Engine: 434sbc
ok thanks. i know alky burns faster than gasoline. i just didnt know how much faster. if your not having any problems, i doubt i will. i ordered a 4 gal cell from jegs tonite. i hope to have it on sat. im going to try and put it where the battery used to be( like above). i have to get a copy of the nhra rules as far as covering the portion that sticks out the bottom.
Old Feb 24, 2010 | 08:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It doesn't so much burn faster. It's actually a slower burning fuel. You just burn twice as much to get the same perfect air/fuel ratio.
So I burn twice as much alcohol as gasoline. My sponsor buys me alcohol. I can currently get it for $300/drum. If I use 2 drums in a season, that's only $600. Because of the high compression in my engine, I would probably have to run C14 race gas at $1000/drum. Alcohol is much cheaper to use.
If for any reason, I run out of fuel, I can run down to Home Depot and buy all their methyl hydrate at an overinflated price but at least I'd have some fuel.
Old Feb 24, 2010 | 10:24 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Not to get off subject but your getting 4 gallons to 1 mile in your car...that is awesome haha sorry now back to the subject at hand.....
Old Feb 25, 2010 | 07:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
No. I go 6 miles on 5 gallons. It's a 2 mile trip from the pits, down to the end of the track and all the way back to the pits following the road course. I make 3 passes on 5 gallons. Only a 1/4 mile is at WOT.
If I was pushed/towed through the staging lanes and all the way back to the pits after a run, I could probably do a lot more passes on 5 gallons.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
kyleb24
Aug 15, 2015 08:24 AM
