Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Seats
Old Mar 5, 2010 | 10:18 PM
Jaws031's Avatar
Car: 88 camaro
Seats
Can I put early 90'seats out of a camaro n a 88 camaro
Old Mar 5, 2010 | 11:01 PM
Stephen's Avatar
Car: 87 GTA
Re: Seats
All 1982-2002 Camaro & Firebirds are a direct physical bolt in swap, no mods required. So yes.
The only issue you could run in to, is that is you try to put an electric seat in a car that never had any, or if you put 4th gen electric seats into a 3rd gen that had electric seats. The wires are there, but the plugs are different, so you hafta cut & splice.
BTW, a "search" would told you the same thing a hundred times over. The search feature here on TGO can be your biggest friend & gets you results to your questions a whole lot faster.
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
