Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
how many ram air fabs do we have on 3rd gen's
Old Oct 4, 2009 | 07:25 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
How many guys Moded there 3rd gens to ram air. with the Y intake set up
it was screaming for it!
would love to see them.. i did My 92 back in 93. and thinking there must be guys who have done the same thing.
useing the air box it came with.. making it pick up air from the back of the fog lights..running up into the K&M filters and into the Y..(the air box is still 1 piece)
yes it's dusty..been sitting for 7 years..
Old Oct 4, 2009 | 08:04 PM
RU1NER's Avatar
Re: how many ram air fabs do we have on 3rd gen's
Got a setup a few months ago and have yet to use it and probably never will.
Attached Thumbnails how many ram air fabs do we have on 3rd gen's-img_0107.jpg
Old Oct 4, 2009 | 08:18 PM
SO sombody did make them. Kewl..
i know sombody would.. i did mine back when the car was new. with sheet alum and Rivets..(photo) it's light Wt..
you should use it..they work!
Old Oct 4, 2009 | 08:39 PM
skinny z's Avatar
Does anyone have of these for sale?
Old Oct 4, 2009 | 08:40 PM
RU1NER's Avatar
Hawks makes them but i got mine used, it could have been home made. I have tbi so i would need to get a hose or something but i also just got a 14x3 k&n on the board for a good price so i'll probably use that.
Old Oct 4, 2009 | 10:05 PM
nothing like fresh..cool air..
Old Oct 5, 2009 | 07:00 AM
skinny z's Avatar
If you decide that you want to get rid of it, I'm interested in buying it.
Old Oct 5, 2009 | 03:36 PM
Pyronight's Avatar
Car: 91 firebird/68 Camaro
Engine: 3.1L V6/Ram jet 350 crate
Transmission: T-5/L60E
Axle/Gears: 7.5 10 Bolt/3.90 posi
Here check this out. I made it custom for the car as the crappy stock air intake wasn't working worth a crap. If I know what kind of intake you have I can fab one for you.
Attached Thumbnails how many ram air fabs do we have on 3rd gen's-downsized_1001090747.jpg   how many ram air fabs do we have on 3rd gen's-downsized_1001090747a.jpg
Old Oct 5, 2009 | 03:46 PM
Stephen's Avatar
Car: 87 GTA
That isn't Ram Air, not even Cold Air.
All that does is increase the amount of hot under hood air an engine can breathe.
Old Oct 5, 2009 | 03:49 PM
Pyronight's Avatar
I'm a dumbass. I forgot to include a pic of the ram air tube from the fog light to just under the cone filter.
Old Oct 5, 2009 | 04:18 PM
Stephen's Avatar
Car: 87 GTA
But with it open to the engine bay, it is still getting hot air.
Put a 90 degree turn down befoe the filter, go through the "battery tray" & put your filter underneath that tray, then you'll have TRUE cold air.
Old Oct 5, 2009 | 04:49 PM
Pyronight's Avatar
I wish I could do that. I have the punk a** V6 so I have the IAT sensor over where the old air box was. I thought about that but I have no room over on the old filter side.
Old Oct 5, 2009 | 04:53 PM
Stephen's Avatar
Car: 87 GTA
Sure you can.....
Just extend the piping further, to put the filter down & under the tray. Wouldn't need to move the IAT. For that matter, the ECM doesn't care WHERE the IAT is. It only cares what the IAT reads. I moved mine from under the plenum out to just behind my MAF, by a good 2.5 feet difference.
Old Oct 5, 2009 | 04:55 PM
Pyronight's Avatar
Sure you can.....
Wouldn't it get wet under there?
Old Oct 5, 2009 | 04:59 PM
Stephen's Avatar
Car: 87 GTA
With the one I posted on the LS1 3rd gen, I would add a splash guard around it, to stop water from coming off the tire & on to it.
Maybe a plate underneath to stop splash from coming up, but in his case...The filter is closed on thee bottom, so that amounts to the same thing.
Old Oct 5, 2009 | 07:18 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I used to have my CAI in the same spot as the above LS1 3rd gen and I never had problem with water getting into the engine. But when I removed it, it was pretty dirty...
Old Oct 27, 2009 | 03:50 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Here's my radiator box I fabb'd up. Converted it to a front breather. Cut open the bottom of the air boxes too.
http://www.fototime.com/inv/A8493E1502C7294
It pressurizes the box creating a slight ram air.
Old Nov 2, 2009 | 09:59 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Here's mine...
https://www.thirdgen.org/forums/auto...-air-pics.html
Old Nov 2, 2009 | 11:40 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
heres mine, i kno its a firebird but i kno u love it
Attached Thumbnails how many ram air fabs do we have on 3rd gen's-p1020070altered23.jpg
Old Nov 3, 2009 | 01:55 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Where is your air filter?
I've been working on modeling the ram air boxes, but with a twist. I'm not ready to disclose that yet...
Old Nov 3, 2009 | 10:00 AM
Guest
Guest
Posts: n/a
Are we sticking to EFI only? And who else has routed air in from where the high beam bulb should be? (Camaro)
Old Nov 3, 2009 | 11:45 AM
Stephen's Avatar
Car: 87 GTA
This would work for a carb/TBI, or the aftermarket TBI body-style port injection systems. Would work great on 2 of the Camaro headlights & still give you 2 headlights to use.
http://www.summitracing.com/parts/SPE-717/?image=large
Old Nov 8, 2009 | 10:37 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
I am trying to figure out how to make a ram air setup using my ss hood. Im in the process of converting to carburated too so Im not really sure which direction I will take.
Old Nov 9, 2009 | 04:20 AM
Twin_Turbo's Avatar
Did you get that off ebay?? If so, you outbid me and now you won't be using it????
Old Nov 12, 2009 | 05:35 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
I had ram air boxes fabbed up that look just like the hawks version. Really surprising how much of a difference that made with all the restrictions removed.
Old Nov 15, 2009 | 04:44 PM
Car: 87 TA clone
filters are located in the hood scoops... they are old K&Ns. i wanted a cleaner look than my old setup. the ram air is made of aluminum and seals against the hood when closed with weatherstripping. so it sucks cold air from the outside and at around 45-55mph it then begins to be forced in for the ram air effect.
i was always jealous that the camaros had the ability/room to have ram air.
Old Nov 15, 2009 | 06:54 PM
RU1NER's Avatar
________________________________________________________________________________________
LOL Sorry, I planned on using it and ripped out all of the plastic pieces but then got a good deal from a member for a k&n filter and xstream lid
Old Nov 15, 2009 | 06:58 PM
Twin_Turbo's Avatar
will you consider selling it???
Old Nov 15, 2009 | 08:06 PM
RU1NER's Avatar
I'm assuming shipping would be very expensive because the boxes for it are big.
Old Nov 15, 2009 | 08:13 PM
Twin_Turbo's Avatar
How big is it? I have a US shipping addy too
Old Feb 28, 2010 | 12:34 AM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
I know its an old post..but do you have a pic of what you did with your airfilter..I am doing the same thing but was still deciding what filter to use.. thanks
Old Feb 28, 2010 | 01:04 AM
Car: 87 TA clone
umm i used a universal K&N rectangle filter... i think it was 4-5"x12-16" and it was about 1" thick. i tucked it up into my ram air hood scoops. so the filters are actually located in the hood, between the outside grill and the inside fiberglass hole that was cut.
Old Mar 4, 2010 | 01:01 AM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
This is what I have now, just double what I have seen on here so far.
I believe this worked much better, it "rammed" way more....LMAO
Old Mar 6, 2010 | 10:08 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
My car came with the K&N ones that OP has. The other owners already had it on the car.
1992rs/ss
Jan 31, 2025 05:10 PM
eightsixseven
Dec 16, 2024 01:50 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
bryan623
Aug 10, 2015 11:33 AM
