Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fuel pump access door! this may help you out!
Old Apr 6, 2010 | 11:43 PM
defaria27's Avatar
Car: 1992 Camaro Z28
Axle/Gears: factory 373
OK...so i have a 92 camaro z28, and just put in a 350 engine in it with carb...no more ecu and imm. So..i ran my own electric pump by summit and holley reg. OK....so i tried this and it DOES NOT WORK, if u put a external pump. You need to take out the OLD IN TANK DEAD PUMP. if you don’t you pump will not last and be extremely LOAD....and it wont give ur engine the fuel u need. So...i decided to take it out....but to take the fuel pump out u have to do a a lot of work. till i stumbled across the access door that you can mod for your trunk...let me tell u...save me sooo much time and when ever I want to mess with my fuel pump or anything in involving the tank its very east to get to. so i took picks for this mod to show people how to do it...some people may not like this because i did it the wrong way, but next time i need to get to fuel pump...i don’t have to take out my whole rearEND! AHA .
Attached Thumbnails Fuel pump access door! this may help you out!-before-cut.jpg   Fuel pump access door! this may help you out!-before-cut-2.jpg
Old Apr 6, 2010 | 11:48 PM
defaria27's Avatar
Re: Fuel pump access door! this may help you out!
so this is the measurement and the first cut....1" from the sides ...between the two groves of trunk floor. I drilled a hole so i can use my shear cutters. they were like 70 bucks at home depot ....you dont need them but i had them when i did my floor boards with sheet metal, good investment though. I also use with the access door.
Attached Thumbnails Fuel pump access door! this may help you out!-ready-cut.jpg   Fuel pump access door! this may help you out!-first-cut.jpg
Old Apr 6, 2010 | 11:55 PM
defaria27's Avatar
OK this was the hardest part...cutting the lines....YES YOU DO NEED TO CUT THE lines. u cant snake them through...I tried, but there clamped in from the top tank, the part u can only get if u drop the tank. so u do have to cut them...i didn’t use my pipe cutter yet because it would not fit because the pipes were too close together...I sniped them with a bolt cutter then used my pipe cutter to fix both ends...you will want to have space between both lines when you are done which you will replace with rubber hose (high pressure)
Attached Thumbnails Fuel pump access door! this may help you out!-lines-half-cut.jpg   Fuel pump access door! this may help you out!-lines-cut..jpg
Old Apr 6, 2010 | 11:57 PM
defaria27's Avatar
OK one the lines are cut. you have to move the locking ring...i used a flat head and hammer...don’t hit it too hard. Ok then u pull up...than to the right...and should come out.
Attached Thumbnails Fuel pump access door! this may help you out!-pump-ass.-out.jpg
Old Apr 7, 2010 | 12:02 AM
defaria27's Avatar
ok..now this is were i got into the zone and forgot to take picks! im sorry. but let me explain what i did. Now you take the assembly out. Take of the black factory strainer, and pop the bottom of the pump out…. and it should slide off the pick up line. then i unpluged it and zip tied it to the pick up line so it was out the way. OK now...if your just replacing the pump, put on exactly the way u took it off...for me i had an external pump...so i just kept it off..but now the pick up line is too short...so what you do is get some of the same high pressure hose...clamp it to the pickup line (you one you took the pump off) and make is same length as the bottom of the factory pump . buy a universal strainer clamp it on the end and your golden.
Old Apr 7, 2010 | 12:06 AM
defaria27's Avatar
ok now put the pump back in the same way you took it out..make sure you get a new seal ring ....its like 3 bucks. now just attach the lines with high pressure rubber hose and clamps!!!!!!!!!!!!!!!!!!!!!!!!!! test your fuel pump. make sure there’s no leaks! The access door is currently drying from its paint job so ill post the rest tomorrow! Hope this helps! P.s. i an going to wire brush them lines...its only surface rust only on the top.
Attached Thumbnails Fuel pump access door! this may help you out!-lines-done..jpg
Old Apr 7, 2010 | 07:13 PM
Pocket's Avatar
Car: 91 Trans Am
A few problems
1) High pressure EFI line isnt necessary for carb pressures and will NOT survive long inside the tank submerged in gas. Pull it out and use submersible hose
2) With the pickup flopping around in the tank you may experience starvation around curves, even when you're not severely low on fuel. The stock pickup is located inside several baffles to keep the gas at the pickup
3) Your carb may not notice any ill effects from this mod, but EFI engines operate at a much higher pressure and where your feed line is reconnected (generally with rubber hose/clamps) is vulnerable to rupture
If you had a 4th gen, this mod would be A-ok, all my gripes are easily remedied, but your 3rd is different. Please dont spread this as the gospel, Im tired of welding up botched floor cuts
Old Apr 9, 2010 | 02:58 PM
83 Crossfire TA's Avatar
so what exactly is different about 4th gens that makes this OK and not on 3rd gens?
Old Apr 9, 2010 | 03:29 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Do you plan on a flare // double flare where the hoses are clamped?
I'm not hip to this kind of stuff, but my , I would give the hose clamps something to hold on to.
Old Apr 11, 2010 | 07:25 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i dont see why people think they need to drop the rear to drop the tank. i just dropped mine to swap the pump and i just had to pull the exhaust, the rear stayed in and gave my no troubles.
Old Apr 11, 2010 | 07:29 PM
Pocket's Avatar
Car: 91 Trans Am
Lines end inside the cutout area, so none have to be cut to remove the sender
Old Apr 15, 2010 | 12:29 AM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
IMHO
I don't think this should be a tutorial.
Its not restoration or modding for that manor its destruction.
Even when its done correctly, (if there is such a thing) Its sketchy at best. Gas Fumes everytime i drive, reminding me how i was too lazy to do it the right way? No thanks.
Good Job on the idea of fabrication and DIYing. Maybe you could write a follow up on how to fix this hack job?
Old Apr 15, 2010 | 12:46 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I just replaced the heater core on an '88 Camry for my daughter and I am not lying when I say dropping the rear/gas tank on a camaro is easier....do it right and drop the tank.
Old Apr 16, 2010 | 09:04 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Here we go again....
And JackRS...if you were to get gas fumes in your cabin after doing the "trap door mod"...you did something wrong. Shouldnt be any fumes coming through it at all.
OP: I agree with what Pocket said regarding the pick up hose etc. And I also agree with maybe flaring the lines, even with a single flare. There isnt that much pressure, but its just added insurance.
J.
Old Apr 16, 2010 | 09:22 AM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
i would think that using no flexible lines in the tank would be better. i just pulled my tank and took out the pump. i replaced it withe a high pressure fitting ( union fitting-brass) and fit in a peice of steel line to match the length, i kept the flare on the end to slide the screening over , and clamped it on. now it shouldnt ever fall off. it also runs through the ring on the bottom ( obviously) but now all the lines in the tank are metal . i also pulled the wire out for the old pump and pulled it from the pigtail . works good.
also i used to use that factory tank pump on my carb.!! you can do this if you desire , but i hated having all the extra wires and switch for it , if you want to use it you can hook the pump up through the relay to a switch. then you need a high pressure/low pressure regulator with a return. i ran mine like that for 6 years, and the factory pump was still good the day i took it out
Old Apr 16, 2010 | 09:27 AM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
now i have an 80 dollar regulator that i cant use anymore cause its desined for high pressure to low pressure, so my block pump cant push more then two pounds through it, oh well , ill have to get the right one for the setup i have now,
i also seen on one of the posts here that someone was running the factory pump on a carb and had a regulator, but couldnt get the pressure below 15 lbs...thats because he had the wrong regulator.. if i find him again , ill see if he wants my regulator.....or maybe he will see this post and find me , who knows, anyway the setup i had with the factory pump does work..
Old Apr 16, 2010 | 09:32 AM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
as far as cutting the access door in the back,,, what for? if your not gonna have an electric pump in there anymore, then what do you need the door for? i guess if you dont put new lines in , you may need to get at the tank again. so just put new lines in, then your good til you die. or put in stainless or aluminum lines, or whatever you prefer, shouldnt need to get in there again.
Old May 2, 2010 | 08:08 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
What size are the fuel line? I want to buy the metal connectors after they are cut instead of the hose but not sure what size to buy.
Old May 2, 2010 | 08:50 AM
Pocket's Avatar
Car: 91 Trans Am
3/8" feed and vent
5/16" return and EVAP
Old May 2, 2010 | 09:03 AM
rdhanded2's Avatar
Top Answer: 1
Thank you!
Old May 3, 2010 | 09:47 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Mines been like that since before I bought the car, and I have never smelled gas, or heard a squeak out of it...It was siliconed, and machine screwed shut....I just discovered it today when I dropped the tank.....Quite a surprise....
Old May 11, 2010 | 02:05 PM
RedKnight79's Avatar
Car: '91 Pontiac formula
Engine: 350 tpi
Transmission: Th700R4
I managed to remove the sending unit without cutting the lines to install a new pump i just had to cut a 7"x 12 1/2" hole and dropped the tank where it sat on top of rear end and exhaust pipe which gave me 1 1/2' space between the tank and the hole and moved the sending unit around and fished it out, no worries. I got pics and will be posting them on my profile soon to prove to some folks that said there was no way but cutting the fuel lines to get the sending unit out.
Old May 11, 2010 | 03:39 PM
Pocket's Avatar
Car: 91 Trans Am
Why cut a hole if you're already dropping the tank?
Old May 11, 2010 | 05:57 PM
Engine: 350 tpi
I didn't drop the tank all the way out, I just removed the tank straps, let the tank rest on top of the rear end and the exhaust that i didn't have to cut. Being accustomed to working on cars on a lift and not having that luxury anymore, working on the ground wrestling an emtpy tank running a risk of jacking up the filler neck, I choose not to do it. Plus I was confedident that you can get the sending unit out without cutting the fuel lines when the disconnects are not far away and I succeeded by cuttting out a 7"x12 1/2" hole which was a little bigger from everyone elses. Dropped the tank where i had room to work and fished that sucker out. It took pretty much the same time to get it in and out as the standard way just without wrestling on the ground part which I enjoy not doing
Old May 11, 2010 | 08:22 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Originally Posted by JackRs
IMHO
I'm sorry but I have to say something. It seems every single post someone attempts to make on a fuel pump access door, even the ones that are done correctly gets bashed and labeled a hack job/******* fix.
IIRC, the fuel pump access door was STOCK on the 4th gen. So why is it OK that the 4th gen comes with this part stock, GM obviously learning from their mistake, while the 3rd gen does not and anyone who even THINKS about doing this mod is labeled a hacker fixer upper?
If YOU want to gripe about how EASY (and interesting for the mod!) this job could be and spend hours on your back taking apart a good portion of the rear of the car, be my guest.
Personally if my FP ever goes out, F going through all that headache and F paying all that labor, the shears are coming out. I think if done PROPERLY IE a proper sized and clean cut hole, paired with a properly fastened lid and GASKET SEALED to eliminate foreign material entering the car, this mod is one hell of a wise decision.
BTW if you have that large of a quantity of fumes entering the car in any which way you have a MUCH bigger problem on your hands than a hole in your floor. I would be concerned about where the leak in my fuel system was. If you don't believe me, try driving down the street with your gas cap off. The small amount of gas spewing out the filler neck is potent enough to fill the inside of the car with the scent WHILE DRIVING AT 40MPH WITH THE WIND SUPPOSEDLY CARRYING THE FUMES AWAY.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
