Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
low pressure?
Old Apr 16, 2010 | 08:05 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
low pressure?
not sure this is the right place for this but,,,
I have an IROC hood with the 2 openings in the rear of the lower areas cut out. If I make an air box that isolates the carb from the engine bay and seals to the hood, will the air that passes over the hood cause a low pressure area and pull fuel OUT of the carb, or , act as a "ram air" hood? At least act as a cold air intake?
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
dcbsracing007
Aug 18, 2015 07:24 AM
BurlyChev
Aug 16, 2015 09:08 PM
jackhammer
Aug 15, 2015 10:04 PM
