Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
chin spoiler mod
Old May 10, 2010 | 07:29 PM
UDAMON's Avatar
Car: Mazda Protege5
chin spoiler mod
something ive been wanting to do for a long time. finally started cutting. also a picture of it mocked up on the car to give you an idea of how it will look finished (which i dont know when that will be, ha.)
Old May 10, 2010 | 08:51 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: chin spoiler mod
Not bad.
Old May 10, 2010 | 08:54 PM
kjvail1204's Avatar
That is sweet just a little adjustment and it makes it unique, I might try this after i get my fuel tank put back in and my cowl hood modified...I want to cut the cowl and make it a ram air style...
Old May 10, 2010 | 09:53 PM
Project-RS's Avatar
im doing a custom fiberglass chin spoiler. its in mock up right now. pm me if you want to see
Old May 11, 2010 | 10:38 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I like it! If you fill in the little corner edge that you can see from an angle in the third picture it'll look even more finished. Maybe also put some kind of bottom on that cut section to help support it... without that it may flex significantly when driving.
Old May 11, 2010 | 11:47 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I like it too! Who would've thought such a small mod would make such a big difference?
Old May 11, 2010 | 02:37 PM
UDAMON's Avatar
Car: Mazda Protege5
thats all part of the plan. you'll see it when done. just giving you an idea so far.
Old May 11, 2010 | 02:45 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
I like it get to work D**it we are all waiting you tease
Old May 11, 2010 | 02:55 PM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
I like what I see so far.
Old May 11, 2010 | 03:37 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You need to rebuild the bottom of the spoiler to make it look like a pro job, but nothing a little fiberglass work wont fix. Looks good.
Old May 17, 2010 | 06:26 PM
UDAMON's Avatar
Car: Mazda Protege5
no work + no rain = progress
bonding the lower section in
hopefully rain holds off for tomorrow and i can get the ends built up and close to finishing it!
Old May 17, 2010 | 07:58 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
This is kinda cool actually, as most of us scrape the roads regularly with the chin spoilers, this might reduce that significantly.
Old May 19, 2010 | 06:59 PM
UDAMON's Avatar
Car: Mazda Protege5
started filling in the ends. here are some more PROGRESS pictures....
sorry for the bad pics
Old May 19, 2010 | 07:21 PM
camaroz2887's Avatar
Car: 1987 IROC Z
for such a small adjustment it changes the looks dramatically. I like it.
your gonna have one very nice car on your hands when its all said and done
Old May 19, 2010 | 08:10 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
I like it. Trying to visualize how to drop the two outer sections down instead of cutting the center out. your way is probly the best / easiest to upgrade the allready great looking GFX. This seems like a tastfull modd great job dude.
Old May 19, 2010 | 08:15 PM
UDAMON's Avatar
Car: Mazda Protege5
thanks guys!
originally i wanted to extend the ground effects like you mentioned. i wanted to go all the way around and just exaggerate the factory lines. like on the rockers going wider and lower on the ends and tapering to stock in the middle. but good luck finding a used set for a decent price that you are just going to cut up anyways!!
Old May 29, 2010 | 07:56 PM
Project-RS's Avatar
i loike what you did with yours. i went a little extreme on the cutout......lol heres what it looks like as of 830 tonight.
Old Jun 1, 2010 | 12:32 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
UDAMON what Headlights are those?
Old Jun 1, 2010 | 10:51 PM
UDAMON's Avatar
Car: Mazda Protege5
off a silverado = https://www.thirdgen.org/forums/memb...light-mod.html
havent had a chance to finish up the spoiler yet. stay tuned...
Old Jun 2, 2010 | 12:28 AM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Looks good
Old Jun 2, 2010 | 04:51 PM
thanx for the link
Old Jun 2, 2010 | 06:41 PM
Mathius's Avatar
Did you ever take off the stock part? After he did that cut, he was left with a hole. That area is hollow, not built up. You'll see it in the later pictures he posted.
Fiberglass won't fix that. It isn't flexible enough and it will just crack, especially when bonded to the original plastic part. I know, I tried to repair mine that way. He could fiberglass the whole part and it would probably work, but it probably wouldn't be as durable if he were to scrape on the curb or something as the flexible stock piece.
And I don't think an epoxy bond will work either because the area is just too big. A plastic weld is probably what's in order at this point or some other kind of chemical bond. I've seen some photoshops of this in the past, but I don't remember seeing anyone do this before aside from some steel pieces done in some old body work books I've seen.
One of the photoshops entailed lengthening the original spoiler and THEN making the cut, the result of which gave the front spoiler an aggressive knife edge look.
There was also a company doing a kit at one time that did a variation on this mod, only they molded it into the bumper cover and changed the whole front fascia.
Mathius
Attached Thumbnails chin spoiler mod-redsshoodwblackracingstipes.jpg   chin spoiler mod-f-_terbowrock.jpg
Old Jun 2, 2010 | 06:48 PM
Twin_Turbo's Avatar
wasn't that called the IROC II???
Old Jun 2, 2010 | 07:07 PM
Mathius's Avatar
Could have been, it does say Iroc on the spoiler. Might even say iroc ii, hard to tell from those pics. There have been tons of mods and kits, etc. over the years. Originally I joined this board back in '98, but my account was deleted at one point due to a board swap or something, I don't remember. Over the years I've just collected pics of all the different things I've seen. Some of the kits aren't offered anymore, some of them were only hearsay back when they were originally posted. The Danko kit for example. I found one pic on their web site, and nothing else. Never heard of anyone actually purchasing it.
I got rid of my camaro nearly 6 years ago, so I'm not nearly as enthusiastic about this place as I once was, and I'm not crazy about the percentage of stock ***** here. I'm probably not up and up on the newer offerings in the last 4 years or so.
Mathius
Old Jun 2, 2010 | 08:08 PM
Twin_Turbo's Avatar
found it!
Attached Thumbnails chin spoiler mod-775309_534_full.jpg   chin spoiler mod-775309_535_full.jpg
Old Jun 2, 2010 | 11:45 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I like it, makes the car look like it has a handlebar mustache.
Old Jun 3, 2010 | 08:21 PM
UDAMON's Avatar
Car: Mazda Protege5
hahaha should have some update pictures tomorrow evening.
Old Jun 3, 2010 | 11:11 PM
MT91Camaro's Avatar
Car: 1991 Camaro RS
Engine: ewww...the 3.1L
Transmission: Not sure. It shifts quite hard.
Axle/Gears: 3.23 8.75" 10 bolt
LOL! Imo, anyone can have a "stock" car. What you do to the car is what makes it "yours".
Old Jun 4, 2010 | 01:54 AM
Str8upChevy's Avatar
Car: '91 RS, '72 Pro/Street Z28
Engine: 305 TBI, Blown 468ci w/NOS
Transmission: 5 Spd, 2 Spd Powerglide
Axle/Gears: 3.08, 4.88
Obviously with any public forum, everyone has the right to voice their own opinions. I guess it only bothers me when some kid starts a thread about a modification he did, and then posts a few pictures to show off all his hard work and satisfaction that he got from it. It's when some purist then comes along and says something very negative about it and bashes the kid for cutting into HIS OWN car. Now on the other hand, if the threads starts off with "What do you think?....well that's completely different!
I couldn't have said it better myself!!!
Ok, now back to the topic.......I think that small little modification you did gives it enough of change to make it look pretty good. Great Job man.....way to go!!! Something I'd probably do though, is use some sort of countersink screws instead of the ones you have on it now. It would make it much easier to put a smooth finish over.
Also, that picture of the dark blue IROC II above,....it kinda reminds me of a 87-88 "Fiero-GT" with one of their aftermarket chin spoilers.
Old Jun 4, 2010 | 09:32 AM
UDAMON's Avatar
Car: Mazda Protege5
the screws wont be staying. i couldnt get any kind of clamp on the pieces to hold them while the glue dried so i used those.
Old Jun 4, 2010 | 12:12 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Yes, I removed that part from a camaro i parted out several years ago and I know it's hollow. That's exactly why the corner where it was cut needs to be filled in with a small vertical section so you can't see that it's hollow looking at it from an angle.
Also, I agree with what you said about fiberglass not being the right tool for this job. Urethane isn't easy to modify; I looked at doing some modifications to my front bumper cover and decided it wasn't worth it.
Old Jun 4, 2010 | 04:14 PM
UDAMON's Avatar
Car: Mazda Protege5
still needs some fine tuning. the center point looks to be a little to the right (left, in the picture).
Old Jun 4, 2010 | 04:38 PM
If you didn't point that out I wouldn't have noticed the point being shifted, I thought it was camera angle.
Old Jun 5, 2010 | 02:11 AM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
looks very aggressive goes perfect with the hood, 2 thumbs up
Old Jun 5, 2010 | 02:27 AM
travis401's Avatar
Car: 91 Camaro RS
I just had an idea. Instead of cutting the bottom off, why not cut a section out of the top, then move the whole piece up. That way the center still has the factory finished look on the botom.
Old Jun 5, 2010 | 03:26 AM
Yeah but you'd still have to fill in the corners. still might make for less repair tho. you wouldnt have to drill and screw the base as he did to reglue it. you just might have something going here
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
