Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
How to get these tail lights?
Old Sep 30, 2010 | 12:32 AM
claytonjn's Avatar
Car: '92 Camaro Vert
Engine: 305 TBI V8
Ok, so since getting my Camaro a couple months ago I've decided I don't particularly like the grid style tail lights. I've made a couple crude mockups of what I want my tail lights to look light. One with chrome trim and one with red. I would want them to be like the non-grid tail lights, but without seems between the lamps. Also, I would like to switch the colors so there is red on top and orange on bottom. I would also want the lenses tinted (about 50%)
In terms of functionality, I would want LEDs. I would want them to work sequentially like the ones from spaghettiengineering.com, but want the sequence to span all three lamp housings. (Does this make sense)
Anyone have any idea how I could accomplish this? I have pretty much no experience with any fabrication... Thanks!
Attached Thumbnails How to get these tail lights?-tail-lights_0000_red-split.jpg   How to get these tail lights?-tail-lights_0001_chrome-split.jpg
Old Sep 30, 2010 | 01:39 AM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Re: How to get these tail lights?
you could maybe tint stock ones with lens tint?
Old Sep 30, 2010 | 01:42 AM
claytonjn's Avatar
Engine: 305 TBI V8
yeah that I could probably do pretty easily. Its changing the colors and getting LEDs set up to work right with it that would be the problem..
Old Oct 1, 2010 | 05:28 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I would start with the non-grid style taillights, probably 2 sets will be needed. Start buy cutting out one upper orange section and one lower red section. Cut carefully with die grinder and cutoff wheel or dremel. Cut the replacement pieces from one of the other pair of taillights and epoxy them in place. Pick up a sheet of ABS plastic on Ebay, or some plexi at Lowes/Home Depot and cut your filler strip between the upper and lower lights. Use some VHT or similar tint paint to get the shade you want.
As for the LED's, there is a thread on here somewhere detailing how one guy did the conversion. It's very thorough, but I can't remember if its in the Body or the Electronics forum.
Old Oct 2, 2010 | 12:26 AM
claytonjn's Avatar
Engine: 305 TBI V8
Getting two sets is a pretty good idea. Anyone know if the orange and red sections are the same size?
I saw some custom lights from (klearz.com I think) and I thought maybe I could convince them to make this style but all of the ones I've seen from them are grid-style so that's probably the only mold they have.
Old Oct 2, 2010 | 07:17 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Yeah, that's the only style I've seen on their website. I have the older style on my Camaro and the yellow and red parts look like they are the same dimensions. I'll try and grab some measurements when I get home from work and post them up.
Old Oct 2, 2010 | 07:34 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Not sure if you already know but there were a few different versions of the earlier taillights. One with the center left alone, one with the center section painted flat black and another that had trim in the center section (the same as where the silver is on the image below). Berlinettas had this in gold BTW.
The idea of changing it to red on top and orange on bottom is interesting, but the bucket where the bulb sits would have to be split somehow -probably would have to be rebuilt. LED's may solve this, but remember too that part of the taillight laws require that they reflect so that other cars passing by can still see it while it's parked.
Old Oct 2, 2010 | 10:51 AM
claytonjn's Avatar
Engine: 305 TBI V8
I did see some of the ones with the trim like you mentioned. I would probably just buy a pair of those (If I could find one) but I want the trim on the bumper to match.
Looking at my lights, it looks like the lens (front part with the color) can be removed from the whole assembly fairly easily. I would just take that part off and leave the bulb housing and everything intact. The previous owner of my car chipped the tail lights on it pretty bad, so I could practice on them. I have a second set of tail lights I could put on in the meantime too.
I think tinting the lights to about 50% would allow them to still be reflective.
Old Oct 5, 2010 | 11:23 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
yea, id say get some berlinetta lights like mine and just paint the strips that run horizontal the colors u like. heres a pic of mine:
Old Oct 5, 2010 | 12:21 PM
Scorpner's Avatar
Engine: V6, V8
This exactly.
I guess they came in silver too.
Old Oct 5, 2010 | 12:34 PM
vinny83's Avatar
lol yea, these are stock off my '83..
Old Oct 5, 2010 | 06:19 PM
claytonjn's Avatar
Engine: 305 TBI V8
After thinking about this more, it may work for those two sections but the part where it wraps around would still be red on bottom instead or orange. Does anyone know if the coloring of the lights is from colored translucent plastic, or if it's just translucent paint? If it's just paint I could just repaint the inside but if not I think I'll have to try to find someone who could custom mold them for me.
Old Oct 5, 2010 | 06:55 PM
Stephen's Avatar
Car: 87 GTA
The orange lenses are molded orange plastic, but can easily be repainted with Testors Translucent Red & will look good afterwards.
Old Oct 5, 2010 | 06:58 PM
claytonjn's Avatar
Engine: 305 TBI V8
All you did to get them to look like that is paint in inside with the Testors Translucent Red? Any clue how I could turn the red sections orange?
Thanks!
Old Oct 5, 2010 | 08:45 PM
Stephen's Avatar
Car: 87 GTA
Thanks!
Those are BigBadLou's taillights. I think he painted the outside, but most just paint the inside.
You can search Testors Translucent Red here on TGO & you'll several have done (painting inside or outside), and/or you can PM him to ask what he did.
Old Oct 5, 2010 | 11:18 PM
claytonjn's Avatar
Engine: 305 TBI V8
Just saw a picture of a European Camaro and the outer two sections were orange instead of red. If I could get a regular set of the non-grid style and a European set of the non-grid style it would be pretty simple...anyone know what my chances are of being able to find European non-grids? Were they even made?
Old Oct 6, 2010 | 09:16 PM
claytonjn's Avatar
Engine: 305 TBI V8
Here's two more mock ups. I think I like the one that's like the Bird style with red all the way across. The other is white all of the way across, the middle white section would be back-up, and the outer three would be for turn signals. The turn signal would me more of the euro clear style but the LEDs would be orange obviously. Like I said, I prefer the bird style better.
Attached Thumbnails How to get these tail lights?-tail-lights_0002_red-white.jpg   How to get these tail lights?-tail-lights_0003_red-white-orange.jpg
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
