MSRed91Camaro
close
- Join DateMar 2009
- LocationEvansville, IN
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- CarI have a 91 Camaro RS
- Engine383 stroker
- TransmissionStock automatic 700r4
- Axle/GearsI have 3.73 Gears with a Eaton posi
- Liked:0 Times in 0 Posts
I have a buddy who is getting a intake manifold powder coated for like 75.00 and with it being such an affordable price I was thinking about getting some stuff done. I am planning on a new engine swap within the next year or two so I wouldn't mind doing the manifold when I do the swap but I was wondering what else I could do. So if any of you have done this to some parts let me know post some pics etc.
You can powder coat almost anything. Engines look really good when coated vs. paint. All you need to make sure is all bolt holes are clean before you put the engine back together.
I'm going to get the brackets and MiniRam done on mine.
MSRed91Camaro
close
- Join DateMar 2009
- Engine383 stroker
Thats cool I was wondering about doing some of my brackets
i beginning to stray away from powdercoating. Yes it looks nice when its new, but if it gets chipped, rubbed, faded, ect, its a bitch to touch up. I going back to paint personally on most things.
Pillsbry10
close
my entire motor is powdercoated, block, brackets, intake etc...looks great
MSRed91Camaro
close
- Join DateMar 2009
- Engine383 stroker
thats pretty sick looking
Pillsbry10
close
its aluminum pc on the block and brackets, black on the oil pan, and teal on timing cover, valve covers, and intake plenum.
all turbo hot side is an aluminum high heat coating
You didn't powdercoat the heads, I assume right?
How's it holding up, on the block? What did that set you back, if you don't mind me asking? Looks good
Pillsbry10
close
yes the heads are done as well
its holding up great, car hasnt seen much road time since motor and turbo but its holding up as good as anything would, lots of people think that the powder will hold more heat in but it doesnt car runs the temp its supposed to
it didnt cost much as i have a buddy that did all of it
Oh that's awesome, I was hoping you'd done the heads too actually. I've got a pair I want to powdercoat (well, a whole motor actually) and I was afraid it might not hold up well around the exhaust ports
The theory about powdercoating holding more heat in is BS, at the temperatures motors operate in anyway
Pillsbry10
close
not a problem there, ive had the headers off multiple times and no sign of wear
I had my TrickFlow heads and RPM Air-Gap manifold powdercoated clear. The heads have held up great, the intake has dis-colored a bit around the carb base though. Other than that I love it, it has the natural aluminum look and cleans up easily.
Quote:
Sounds like powdercoat doesn't hold up great to gasoline eh? That's good to know. I wonder how it does with oilOriginally Posted by gregs78cam
I had my TrickFlow heads and RPM Air-Gap manifold powdercoated clear. The heads have held up great, the intake has dis-colored a bit around the carb base though. Other than that I love it, it has the natural aluminum look and cleans up easily. Quote:
Powder coating holds up very well to gas, oil, and petroleum based substances compared to any other paint be it lacquer, or enamel based. Nothing is going to hold up perfect to constant contact with gas, and oil but powder coating does a near perfect job. The yellowing you might see in a clear is just the gas evaporating and residue getting embedded into the small pores. Also that same yellowing you would see in a clear over time you might never see in a color.Originally Posted by Primetime91
Sounds like powdercoat doesn't hold up great to gasoline eh? That's good to know. I wonder how it does with oil Chipping a good powder-coat is also very difficult. My lift is powder coated red and aside from were I roll the cars up and where the wheels touch the base there is no sign of wear after 3 years. The lift is also washed with full strength degreaser at the end of every month, and touched up in between. Need I mention the constant contact with brake fluid, oil, and antifreeze.
Powdercoating looks great on the TPI and SR intakes, here are mine I did
